Nvidia GeForce 8800GTX
  • I think its either:
    1. a drivers issue
    2. a max issue
    3. a graphics card issue
    4. a OS issue
    5. an issue
    Jonas Andersen
    Cadpeople | Visual Communication
    www.cadpeople.com
    • 6. Global Warming
      Eric Boer
      Dev
      • i m serious leaning on 6 here!
        Nuno de Castro
        www.ene-digital.com
        nuno@ene-digital.com
        00351 917593145
        • jonasa I had this problem yesterday and I found reloading the texture solved the problem
          Chris Jackson
          Shiftmedia
          www.shiftmedia.sydney
          • yes - reloading does indeed help... just a bit inconvenient - and also... I am curious to why this happens.
            jacksc02, are you on latest Nvidia driver as well?
            Jonas Andersen
            www.cadpeople.com
            • im running a geforce 7600GS with the 91.47 drivers
              Chris Jackson
              Shiftmedia
              • im on 97.92... maybe this driver is still buggy with the 8800GTS
                Jonas Andersen
                www.cadpeople.com
                • Maybe, although I have been using that driver now since it was released, havnt seen that problem... "yet".
                  • da force: as capacitors get older they lose capacity, so given your PSU relies on these things - your PSU actually is only able to produce so much power after so much use...
                    i believe you lose 10% every year. so your 680w psu is really 612w one year later!
                    WerT
                    www.dvstudios.com.au
                    • true true.. good point.
                      Well might just buy a 1000w one or something
                      lol over kill.
                      • well...got my computer and everything...except....the Dell 690 only has ONE power connector for the 8800gtx. Did you guys plug two in or is one ok?
                        Eric Camper
                        Studio 3D
                        www.dbfinc.com/studio3d
                        • Well if you only needed one, thats all they would put
                          You WILL need to plug both in. However you can use the supplied molex to 6pin adapters and plug molex plugs into them and plug the adapter into the card.
                          • hehe... Well...I searched the box and did not see any adapters....But we already ordered a new 1100 Watt power supply that supports the extra connectors and etc.
                            Thanx
                            Eric Camper
                            Studio 3D
                            • did you order the power station that goes with it?
                              Chris Jackson
                              Shiftmedia
                              • Eric, this is what they look like.
                                The little adapter thingys on the right.
                                If you didnt get them best to contact the place you got the card and hastle them
