Evermotion - anybody experianced???
  • #16
    Originally posted by toby™
    Well, if you need some help on lights and rendering settings, this site might be useful for you:
    --> http://www.spot3d.com/vray/help/150R...s_interior.htm
    Well that tutorial helped me out to get things started.
    However, it was written a while ago, before 1.5 came out. And before LWF. (do a search on the forum for that)
    So not all settings still apply i think. But the principles are still the same.
    Another tip I can give you is buy the dvd's of Christopher Nichols. I have the Global Illumination: interiors. It has learned me alot about the principles too.
    check http://www.thegnomonworkshop.com/dvds/cni02.html
    To create the lighting like the pic, I think the lighting setup would be
    - VrayLightMtl for the lighting at the top in the wall
    - Target spot with inverse square decay or IES (tutorial on Evermotion for that)
    As they said, there's no one solution to all problems.
    Hope this helps.
    www.vknt.be
    • #17
      Hello VKNT,
      Thanks for your reply!
      I already bought both Chrises DVD's...
      I already used for hidden lights at the top Vray Light material. One interesting thing, maybe a key thing, is Inverse Square parameter. I did not use that yet. I will try it
      Regards
      Srdjan
      • #18
        Well, if you allready bought them, take a look at Chapter 4 of Interiors DVD. That's when he explains inverse square falloff..
        www.vknt.be
        • #19
          Hi VKNT,
          Thank you so much!!!
          I will defenitly pay more attention on that one
          regards
          Srdjan
