Are you on 2010 x64 with the latest sp and extension? It's been a while, but I think my workaround was to close the interface and load it again.
CG-Source.com is launched - High quality textures!
hello guys,
just tried to use multitexture for the forst time, created a floor, used multitexture, but all am seeing is just one single texture repeating on all the tiles....
any idea whats wrong?
THANKS for any soon reply...am on the quite tight deadline)))))
Best RegardsMartin
http://www.pixelbox.cz
I use this quite a lot now and it's great. What are you using for your texture? Have you used several images or just one? Is it a wood texture? I tend to try and use at least 10 textures. If I'm struggling I get a large texture and make 10 small planks from it. Then more textures you use the better the result. It might be easier if you upload a scene with the floor in question and the texture you're using if you've got a tight deadline...
i have used MULTITEXTURES i ve bought on cg-source.....its something above 10 textures i load inside max through multitexture file....its previewing in the mat editor nicely, but in the viewport and in the render i only get one texture repeating!!!Martin
nope....i used the same procedure as Thomas has in has videos.....
little update.....it renders in the VFB fine now, but in the viewport i still have one texture repeating only.....no updates form material editor as well......will try to reinstall the display driverMartin
hmm...why is that so? on the Thomas videos, it automatically updates in the viewport...is that a DirectX driver limitation?Martin
ah...excuse me...am an idiot...it actually works like that((...kinda shame though...it would be useful if it had shown the maps correctly in the viewport
Martin
