plug-in
  • plug-in
    How do you install a plug-in, on a slave, when 3ds max has expired? I downloaded the EGZ Glass shader for a scene and the plug-in is a MZP file that I was able to drag-n-drop into my MAX worsksation. I need it on the slaves too, but I can't do the drag-n-drop.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    i second that question!
    Martin
    http://www.pixelbox.cz
      you can manually mirror dependant files, like plugin.ini and the contents of this directories:
      /plugins/
      /scripts/startup/
      /stdscripts/
      there may be more, depending on the specific plugin.
      Marc Lorenz
      ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
      www.marclorenz.com
      www.facebook.com/marclorenzvisualization
        in case of the MZP script package, it is a only a ZIP file in reality, that extracts itself to the max folder.
        rename it to .ZIP and look what's inside.
        Marc Lorenz
        www.marclorenz.com
          gotcha, thanks.
          How about setting up gamma settings? All of a sudden I have a slave with different gamma settings so the buckets are rendering out different.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            You could always use the portable license utility to transfer the 3ds max license to the slave and the transfer it back.
              gotcha, thanks.
              that would be 3dsmax.ini, if I remember right.
              Marc Lorenz
              www.marclorenz.com
                I'll try both tranfering license and ini, ini being my first effort. Thanks
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  there isn't a 3dsmax.ini, but I am seeing some gamma settings in the CurrentDefaults.ini. I'll try that for now and get back to ya'll
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    it has to be somewhere but autodesk decided that keeping it in the 3dsmax folder wasn't complicated enough, so now it's hidden somewhere in the windows user folders tree hell.
                    Marc Lorenz
                    www.marclorenz.com
