How do you install a plug-in, on a slave, when 3ds max has expired? I downloaded the EGZ Glass shader for a scene and the plug-in is a MZP file that I was able to drag-n-drop into my MAX worsksation. I need it on the slaves too, but I can't do the drag-n-drop.
plug-in
plug-in
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
you can manually mirror dependant files, like plugin.ini and the contents of this directories:
/plugins/
/scripts/startup/
/stdscripts/
there may be more, depending on the specific plugin.Marc Lorenz
___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
www.marclorenz.com
www.facebook.com/marclorenzvisualization
in case of the MZP script package, it is a only a ZIP file in reality, that extracts itself to the max folder.
rename it to .ZIP and look what's inside.Marc Lorenz
www.marclorenz.com
gotcha, thanks.
How about setting up gamma settings? All of a sudden I have a slave with different gamma settings so the buckets are rendering out different.Bobby Parker
phone: 2188206812
- Windows 11 Pro
You could always use the portable license utility to transfer the 3ds max license to the slave and the transfer it back.www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
Originally posted by glorybound View Postgotcha, thanks.
How about setting up gamma settings? All of a sudden I have a slave with different gamma settings so the buckets are rendering out different.Marc Lorenz
www.marclorenz.com
I'll try both tranfering license and ini, ini being my first effort. ThanksBobby Parker
phone: 2188206812
- Windows 11 Pro
there isn't a 3dsmax.ini, but I am seeing some gamma settings in the CurrentDefaults.ini. I'll try that for now and get back to ya'llBobby Parker
phone: 2188206812
- Windows 11 Pro
it has to be somewhere but autodesk decided that keeping it in the 3dsmax folder wasn't complicated enough, so now it's hidden somewhere in the windows user folders tree hell.Marc Lorenz
www.marclorenz.com
