yes. 3ds MAX Design 2011
20gb of RAM but windows is still swapping !!!!
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- ​Windows 11 Pro
at least they are looking at it. I went to the site, but got lost... which board are the talking about it on?Bobby Parker
phone: 2188206812
- ​Windows 11 Pro
I guess thats right...the scene I am rendering is very complex and has a lot of proxies but I thought that memory was loaded and unloaded per bucket to save memory...although Im guessing if you have 8 buckets going at the same time that mayb use a lot more memory. Would turning off hyperthreading help to reduce memory usage ?
Not really, but I do have a fix for this, I think; if you are interested, please email me to vlado@chaosgroup.com
VladoI only act like I know everything, Rogers.
And one note about the crashes:
Well, I am not sure this is the same problem you are having but I wanted to share my discovery. I used the have MANY crashes with 2011 too and found out that these were caused by new Autodesk's file menu.
I couldn't find a way to disable it but I enabled the "max own file" (the old one) menu and start using it and 99% of crashes are gone.
You can enable the old file menu Customise User Interface/Menus.for my blog and tutorials:
www.alfasmyrna.com
I cannot find the old file menu, is this a UI that I have to load ? cause I dont have it.
UPDATE: Ive managed to do it..thanks.
Im assuming you cannot get rid of the New file iconLast edited by stevesideas; 14-01-2011, 03:35 AM.
Originally posted by stevesideas View PostUPDATE: Ive managed to do it..thanks.
Also, how did you get on with Vlado's fix mentioned above?
Cheers,
Olly
