water feature / waterfall
  • water feature / waterfall
    For a new project I need to make a water feature something like this:
Name:	Waterfall Penthouse.jpg
    has anyone done something like that? any tips? anyone fancy making one for me in phoenix or realflow? (I'll pay!)
    peter
    www.peterguthrie.net
    www.peterguthrie.net/blog/
    www.pg-skies.net/
    just did... Photoshop brush
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      3d please!
      www.pg-skies.net/
        Kind of a job for blob mesh, pflow, maybe some curved sheet geometry with a stretched noise map in a displace slot, some bumps and what not.
          tried something like that years ago:
Name:	20100826 test52.jpg
          just thought that in this day and age, fluid simulation software must be able to cope with a simple water feature filling a shallow pool pretty easily? am i misguided?
          to be clear, I want something that looks AWESOME, not just good, and am willing to pay someone else to do it
          www.pg-skies.net/
            Ah okay. Yeah it's pretty easy to do, I'd go with naiad, krakatoa and frost. You'd end up with a prt file for your splashy bit and a vrmesh for your pool.
              Someone at work pulled it off using realflow (and it looks remarkably like the example you've posted) but it was hair-pulling stuff from the looks of it. He spent days doing it and the simulations were at a snail's pace. I've never used fluid-sims before but realflow looked painful.
                yeah i guess it would take me days as well if i bought all the right tools..
                www.pg-skies.net/
                  Film it!
                  This is a quick proof of concept I did a while back - we then spent a couple days with a hosepipe and a black board filming new ones. after collecting a shitload of thin strands I took them into fusion and made a 4k wide, looping animated waterfall. On decent curved geometry, animated noise to shake it up & the map in the opacity and displacement it came out looking great.
                  also plan to film water splashing into a pool from above to do the same for a displacement map on the water surface but we didnt need it for that job.
                    I wonder if you could use those techniques along with this script to get something to work for the way it breaks apart as it falls.
                    Ben Steinert
                    pb2ae.com
                      thats a nice looking script
                        id just use geometry and model it
                          ok next question.. anyone got tips on water material settings for speeding up renders of alembic particles loaded using vrayproxy????
                          www.pg-skies.net/
                            I would go with a simple plane, little bit of modelling, bit of noise and a good shader.. for the upper part.. a scatter for the bottom part, and getting them together. Not a realflow or phoenix solution, but fast n clean! ( of course if this is a still image)
                            Alain Blanchette
                            www.pixistudio.com
                              Peter is there any chance of trying the horrible thing of importing the mesh into your scene? Since vray proxy is more of a get out of jail card for high memory scenes and not the best choice for performance can you bring a mesh in?
