MAX Frustrations
  • MAX Frustrations
    What exactly is MAX does when the dang thing sites at 'not responding', yet my CPU and RAM is practically 100% free? It just sits there and does nothing, forever (3-4 minutes and sometimes more). I can navigate without issues, picking things and doing what I want, and all of a sudden it freezes. Is there something I can do, or shouldn't be doing?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Have you tried disabling the progressive refinement of the Nitrous viewport?
      Hmmm.... not sure. I'll check, once MAX decides to wake up.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        It was enabled, so I disabled it. It doesn't seemed to have helped any, but we'll see.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Well, I can see you have 26 000 objects selected. As far as I know, MAX doesn't like a ton of objects and when selected that makes it even worse. Why not use forest pack to place you trees, that way you only have one forest pack object.
          A.
          www.digitaltwins.be
            not only that, but 26,000 shaded objects.
            when doing loads of trees like that you should really use "display as box" at all times, unless you desperately need them shaded.
              I have found that when I keep it shaded, it actually performs better, or at least the same. Toggling from one to the other takes 30-60 seconds, so I was just leaving it on shaded. The thing is, most of the time everything moves nicely, but out of the blue it'll just sit and spin, for no reason. I can have everything on and shaded, pan and zoom in real time, without an issue. And other times, I can have a hand full of things on and it'll site and spin for 3-5 minutes and then free itself up.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                One plant and it's been siting here for about 5 minutes.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  You do mean the Improve Quality Progressively, correct?
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    I have that sometimes as well, but then max don't recover for me. I already left it for the night but was still frozen the next morning. I usually roll back to the latest autoback, that's why I have it to every 5 min and keep everything to xrefs so the saves are fast.
                    One thing you should probably keep in mind : disable the maps in the viewport, it help a lot with the loading time of the files, but also keep the GPU ram low.
                    Stan
                    3LP Team
                      Disable map in viewports. Are you talking about object color under the Display Color tab?
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        I think Stan means the "Shaded without maps" mode.
                        A.
                        www.digitaltwins.be
                          Gotcha. I'll try that. Thanks!
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            It's really more than just a viewport issue. I can have one thing turned on, let's say one wall. If I pick the diffused slot, as an example, I wait. I have to wait for absolutely every movement, however it's only 1/2 the time. It might just be how it is with a large scene, but it is driving my insane.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              welcome to the wonderful world of max
                              Sorry I couldn't offer a solution.
                              Dmitry Vinnik
                              Silhouette Images Inc.
                              ShowReel:
