Constant Unresponsive
  • #16
    Going from 1 view port to 4, let's not even go there! It takes over 2 minutes!
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #17
      Canceling a render takes a few minutes... all adds up to wasted time!
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
      • #18
        Bobby,
        I'm guessing you work with cad files all the time, bringing cad lines into max. My experience with cad line work, blocks etc. is that it always gives max a hard time. I try to limit the cad stuff I bring into max to just clean polys that I have created in acad and civil 3d surface models exported out of civil 3d as VS3PD files.
        mh
        • #19
          could try resetting your user settings, thats fixed some issues for me in the past
          http://area.autodesk.com/blogs/maxst...-user-settings
          http://area.autodesk.com/blogs/maxst...ngs_in_3ds_max
          also could have a look at this
          http://area.autodesk.com/blogs/maxst...ons-in-3ds-max
          https://knowledge.autodesk.com/suppo...6689D-htm.html
          try cleaner script http://www.scriptspot.com/3ds-max/scripts/cleaner
          • #20
            I'm getting a new machine next week, so all will be new.
            Bobby Parker www.bobby-parker.com
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
            • #21
              I lose at least 2 hours a day.
              I'm not going to comment on the number of crashes I get because it can change wildly depending on what I am doing and how I am doing it.
              That being said, dealing with crashes is a fact of life for us but no professional should ever lose hours of work because of it. Here are two things I started doing many years ago - and since that time I have never lost more than a few minutes of work. In fact, most crashes now are just a simple reboot and on with the job...
              First, create a personal culture of consciously noting the feeling of "accomplishing something", anything that took some time to do - and every time you feel it you simply save the file. Yes, sometimes you will be working on larger files that take longer to save, but I guarantee that waiting for saving in most cases is much better than going back and re-inventing the wheel!
              Second, and any time you accomplish something really significant, go ahead and save with the + sign in the Save dialogue. This will save your project in its current state and is a great way to "freeze the moment" in time forever. I'll save incrementally like this many times per day and I cannot tell you how many times this has saved my butt!
              A hint - Saving takes much less time now that I am using solid state drives for not only the OS and applications, but also for the current project I am working on. When the project is done I archive it on normal drives but having the current project on a fast drive is a real time saver and makes all this saving just that much faster and easier.
              And if you already know all this stuff, then I apologize for taking up your time but hope it might help someone out there somewhere. It sure has helped me and the many folks over the years I have taught it to.
              -Alan
              • #22
                All good stuff! Yes, I save often, however sometimes I do forget. Actually, every save saves a copy, so I have many duplicates. I tend to save 30-40 times a day and I delete all but the last few at the end of the day.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #23
                  PSD manager causes this for me when cancelling renders. I have it disabled and only activate it when I need it.
                  "I have not failed. I've just found 10,000 ways that won't work."
                  Thomas A. Edison
                  • #24
                    Yes, I have found that to be the culprit , too. I emailed them before about it and I think they pointed the finger at V-Ray. I use PSD Manager all the time, so I rarely turn it off afraid I'll forget to turn it back on.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                    • #25
                      Seems like a dying plugin It hasn't been updated in forever.
                      Thomas A. Edison
                      • #26
                        I hope not. Nothing else does what it does as easily.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                        • #27
                          As the developer of psd-manager I feel a little bit offended by this statement (maybe just lost in translation, the term fingerpointing in german has a negativ vibe).
                          To sum it up - if you cancel mid render - psd-manager does nothing. However, V-Ray simply shows the name of the first render effect in the progress dialog, while it or 3ds max itself still cleans up memory or something else (I don't know). We discussed this way back both in the psd-manager forum and in the Cebas forum.
                          For reference: http://forums.chaosgroup.com/showthread.php?69096-PSD-Manager-Slow-to-kill&highlight=psd+manager
                          We both also discussed this delay in the Cebas forum and there you made Mu********er out as the cause. I outlined some simple steps to clearly figure out what exactly triggers this behaviour. Unfortunately the thread is still waiting for your reply. So that is were things stopped.
                          Cebas forum thread: http://www.cebas.com/forum/index.php?topic=152.0
                          I'm not saying that psd-manager could not in some way trigger that behaviour. It has to request certain data from the renderer when rendering begins (G-Buffer channels). However, psd-manager is not responsible for the delay when cancelling the render. The plugin is not doing anything at that point in time - the render progress dialog display text is misleading (just put some other render effect as the first one).
                          Daniel
                          Daniel Schmidt - Developer of psd-manager
                          • #28
                            Not going anywhere - it is around since 14 years! If you can't wait and are interested in Beta testing - send me an email to mail@daniel-schmidt.biz (same for you Bobby) and point out what you love/hate about it and we will work from there.
                            • #29
                              I guess it could be misunderstood as offensive, however, that wasn't my intention. I clearly remember posting on the Cebas forum about the major delay when ending a render, while using PSD Manager, and I was told that once you cancel, basically, PSD Manager waits for V-Ray. So, as far as I was concerned, that was a valid answer. I was almost defending PSD Manager, which is evident in my reliance on the plugin, in my work flow. Anyway, I would love to try anything new you guys are doing.
                              Here is the Cebas forum post (https://www.cebas.com/forum/index.ph....msg873#msg873)
                              Daniel
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
                              • #30
                                Good to know, thanks for the explanation. I'll send you an email about signing up for the Beta.
                                Thomas A. Edison
