Thanks friends
lens effect \ bloom does help a bit to solve the problem.
But what do I do when I render an exr file and I do not want to use buty pass or effectsResult but only use a combination of global illumination, reflection, refraction, etc. Is there a way to integrate the effectsresult layer in Photoshop.
Can you please expand the concept of tonemap and how to perform it in vray or Photoshop?
Hope I was clear
As mentioned uses vray 3.6
Assuming those are vray lights visible in render.
I would disable those from visibility and instead model a light fixture and assign a vray light material to it with multiplier 1.0 and compensate for exposure checked.
Either that or turn on sub-pixel mapping.
