Zigzag
  • Zigzag
    Hi.
    Is there any way to prevent this?
    Max 2020 vray 3.6
      A lens effect will clean that up
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090
      • ​Windows 11 Pro
        Super whites that are having trouble blending with the darker pixels around it. Either bloom it, or clamp / tonemap it.
        Website
        https://mangobeard.com/
        Behance
          Thanks friends
          lens effect \ bloom does help a bit to solve the problem.
          But what do I do when I render an exr file and I do not want to use buty pass or effectsResult but only use a combination of global illumination, reflection, refraction, etc. Is there a way to integrate the effectsresult layer in Photoshop.
          Can you please expand the concept of tonemap and how to perform it in vray or Photoshop?
          Hope I was clear
          As mentioned uses vray 3.6
          many thanks
            Assuming those are vray lights visible in render.
            I would disable those from visibility and instead model a light fixture and assign a vray light material to it with multiplier 1.0 and compensate for exposure checked.
            Either that or turn on sub-pixel mapping.
