Giev me that grass plugin ;O Where I buy it ? :P If I can make invinite grass in 2 clicks that aint seamless like hell I take it , Hope it will render at 15k tho ;O
Could you do trees with this? Put the camera above the mesh tree, and apply the projection to a strip of polygons that would act as trees along a road, for example.
The plugin is out, but with very little info about what it can and can't do.
What's the rendertime of that railtrack image? I like that it has a small memory footprint, but if it takes hours to render then i'd rather buy the extra memory!
Does it support buffers? ie. on that apartment block image, could you use multimatte to extract the window glass like you usually could?
