Export particles?
  • Export particles?
    Hi guys, i have a question, i had a smoke sim and i have forgot to turn on the particles in emiter, and also i did wavelet too
    so is there a way to create these particles after all this, and not to simulate it again?
    thx
    what build? the nightlies have resimulate option, maya official if i'm not wrong also has it.
    ______________________________________________
    VRScans developer
      Phoenix FD for Maya 2012, version 2.0.0 from May 14 2013
      oh? i totally forgot about resimulate, let me try and will see
      thx for the tip
        could you plz guide me,
        i do see resimulate and option for particles only but im not sure im doing everything as i should...
        thx
          when i hit start i got only this
          // PhoenixFD: Preallocating 0 million cells (0 MB) .
          // PhoenixFD: Simulation output will be saved to 'C:\Users\bazuka\Documents\maya\projects\default\d ata\phx_heavysmoke.ma_Phoenix2_frames\@PhoenixFDSi m1@PhoenixFDSimulator1_resim'. Frames 1-150.
          currentTime 1 ;
          // Warning: Phoenix FD: End of velocity data for resimulation! //
          // PhoenixFD: Simulation stopped.
            yes, it's from the resimulate rollout. I'm not sure what you will get with this build however . The nighly builds from the last 2 months are not recommended. Better get a stable nightly or wait for the next nighty if you want the latest features from 3ds Max.
            V-Ray/PhoenixFD for Maya developer
              Did you export the velocity channel? You must export it in order to work with resimulation.
                Read this first http://www.spot3d.com/phoenix_maya_2...tion.htm#resim
                  i have just open the heavysmoke sample, and as far as i can see vel is not on
                  ill try again, thx
                    yeah it works
                    thx for the help
                    p.s.
                    could anyone gimme an access to other parts of the phoenix board? i have restrictions cant see images, etc...
                    thx
                      Hi guys,
                      i have some questions based on particles,
                      when i export particles from phoenix and make the particle system (in maya) i dont see the emiter seed options?
                      i would like to multiply particles with krakatoa, but for this i will need emiter seed, for some reason its gone...
                        forgot to add, most of the things are not even controllable? like lifespan, PP attribs, etc...
                          It's just export. PhoenixFD acts like a particle cache. You can only add extra attributes like radius, color, opacity. If you want emiter, use PhoenixFD Emitter http://www.spot3d.com/phoenix_maya_2...ix_emitter.htm
                            i see, thx for quick replay ivaylo
                            cheers
                            • #15
                              In the last nightly, Phoenix particles can have lifespan also. I suppose we can take into an account the parameter in the nParticle node also. In case you want to shrink the life as a post-process.
