Something I should add - the B2B Interaction should be increased and the foam amount also.
realistic beer foam
Hey guys, thought I would post here as it is a crazy foam issue
Foam is the yellow particles:
https://www.dropbox.com/s/pu4dtzlbpe..._foam.avi?dl=0
Settings (I am trying different settings but no luck)
https://www.dropbox.com/s/2nv979j4ax...foam..jpg?dl=0
Max 2017/PHX 1606266837
** just updated to 29th June build, still exploding.
Thanks!Last edited by flipbook; 30-06-2016, 05:52 AM.Adam Trowers
Alrighty - the cause are the foam pattern forces - for now you can workaround this by reducing those or setting them to zero, and for tomorrow's nightly there will be a change in the way the foam is accelerated by those forces, so it wouldn't jump in the air like thatThanks for finding this issue!
