Originally posted by glorybound
View Post
So I have been trying to set up exterior lighting. I am using a physical camera ( Max 2019 ) the settings for exposure : F Stop / Aperture is 6 ISO is 800 and Shuter is set to 30 frames. What unit type is best for shutter speeds? Frames, 1/sec, seconds, etc? I just kept it on the base unit I assume other unit types have more control or are better in motion.
I have a hdri map set to the my domelight as well as my environment back ground and in the camera viewport the background is also showing. I am using the physical camera settings to drive the exposure control in the environment tab, which I assumed would be correct because I am setting up the physical camera manually.
Ill keep playing and testing, but maybe its something I cant see.
Edit: I forgot to drop my hdri map into my dome light, that seems to help with the over blown image and now I can see my basic test geometry... Now the issue seems to be the hdri doesn't show up in the render at all just pure white hah
Edit2: I set the camera white balance to pure white instead of Illuminat daylight default. That seems to have gotten my hdri to render out aswell. Maybe further tweaking of the rendering output for the hdri map will help balance the lighting.
Cheers, Brandon
