Originally posted by Bigguns
View Post
What about we ditch AcesCG and use AgX ?
Allright, i made ACEScg renders of the same scene, and using my approach now results to nigh identical results to yours.
First image is the standard sRGB LWF render.
On its right, a standard SDR ACEScg render of the same scene (max 2024 defaults, to be clear.)
The line below shows the four look options using the expensive transform from ACEScg to Kraken Log and back.
The bottom line shows the same four options, but simply feeding the OCIO setup a linear input.
the slightly bigger image is here.
emanuele.lecchi@chaos.com
Disclaimer:
Image from:
Testing_Imagery/mery_lightSaber_lin_srgb.exr at main · sobotka/Testing_Imagery · GitHub
this should show some differences between aces odt and AgX odt:
edit:
ACES 1.3 with default gamut compress (built in transform from Resolve)
AgX - aded lut to roughly match contrast of aces odts https://forums.chaos.com/forum/v-ray...16#post1192616
ocio config for testing AgX with some ACES mixed in (improves both acescg and linsrgb input) :
https://forums.chaos.com/forum/chaos...89#post1195589
yes, you can use it pretty much like AMPAS.
just load the config in VFB and start from there.
the AgX version I'm using was designed with linear srgb input in mind I think. So no need for acescg renders although wider gamut is always nice to have.
note on different versions:
the OG AgX from Troy James Sobotka - this is what I included with my config - super simple, very robust. available on github
the Blender 4.0 version - apparently improved, more complicated - you get it with new Blender.
also Krita seems to be one of the easy ways to check different configs. It's quite a mess with level of ocio support between software.
Originally posted by piotrus3333 View PostIt's quite a mess with level of ocio support between software.
Thanks for the help, I will try it.
Originally posted by kosso_olli View Post
That's the problem with color management in general...
ocio is great. no question about it.
Originally posted by kosso_olli View PostI'm interested in testing this, but I really am confused how this works.
We are not on Aces and probably never will be. Can we use AGX the same way as the filmic tonemap correction in the VFB set to AMPAS for example? If so, how is it done?
