cosmos error
    The same problem come back again today, any solution to solve this issue?
    Jackie Teh
    3ds max design 2023, V-Ray 6, Update 2.1 [6.20.07 build 32575]
    AMD Threadripper 1950X @3.40 GHz | 64GB RAM | Nvidia RTX 3070 ti
      the error come back again, any solution to solve this error?
      Jackie Teh
        I guess you already checked that the file is existing on the path from the error?
        Are you using 3dsmax backburner or some form of distributed rendering?
        Is the cosmos folder mapped to a network location or is it local?
        Please note that V-Ray nightly build will try to auto-download when cosmos resources are missing (if that's the case at all).
        This functionality will be available in the next/coming official releases.
        Best Regards,
        Kostadin Terziev​
          guess you already checked that the file is existing on the path from the error? Yes
          Are you using 3dsmax backburner or some form of distributed rendering? No
          Is the cosmos folder mapped to a network location or is it local? No
          Jackie Teh
            I still think cosmo should by default install in the Public directory. This would avoid all the user issues, especially with render farms where the farm user is unlikely to be the same as the workstation user. Every windows machine has the public directory in the same place.
            I just always copy the resources to each project folder, as I want them archived with the project rather than in some system wide directory.
            Would be nice if when you add something from Cosmo it had the option to copy the assets to the current project directory tree automatically.
            • #21
              Originally posted by hristo_chakarov View Post
              1. Ctrl + Alt + Del
              2. Open Task Manager
              3. Select More Details
              4. Go to Details tab
              5. Locate cbservice.exe
              6. See which user owns it
              For the record, this seemed to have fixed my issue. Thank you!
              • #22
                The issue come back again
                Could not read/write file type: C:\Users\Sunway Design\Documents\Chaos Cosmos\Packages\3D_Models\Furniture\Cabinet_48-42_b114f52\Assets\b114f52_Wood_Diff_3dh_srgb.tx
                Jackie Teh
                • #23
                  could you please share how you solve this? I still have the same issue
                  Jackie Teh
                  • #24
                    Hi, this issue keep on coming back when I click the view image in the material editor, if I clear the message I won't show again until I close 3ds max file and re-open again, this issue will pop up again
                    Jackie Teh
                    • #25
                      That message is normal because Max itself can’t read TX files. Annoying as hell, though.
                      • #26
                        Thank you for clarified
                        Jackie Teh
