Cosmos is not working
    Yes, tried everything over and over again, and again with each update, also the last one. Makes absolutely no difference. When my current project is finished (in 2 weeks) I will contact you.
      hi
      can someone help me with this please?
        Hi guy_benzaken,
        Can you please forward us the cb.log file located in C:\Program Files\Common Files\ChaosGroup\ChaosCosmos so we can check for any errors printed?
        Also, have you made any changes/updates recently? Please check if you have both Chaos Cosmos Browser Service processes running by going to Task Manager > Processes. If nothing is running, you can manually start the processes (Windows shortcut, and type Start Chaos Cosmos Browser). See if that makes any difference.
        Nikoleta Garkova | chaos.com
          Cosmos isn't working for me either. It starts normal, I can see my downloaded objects etc. However, when I try to download a new model or import a previously downloaded model, it opens a window in my web browser to login via Trimble. After logging in, I see the same Chaos Cosmos page but in my web browser. If I try to import a model from the web browser version, it just opens another tab with Cosmos loaded. Has anyone else experienced this?
            Hey calvin_ode,
            Is it possible to forward us the cb.log located in C:\Program Files\Common Files\ChaosGroup\ChaosCosmos? Please also mention this thread in the form subject.
            • #21
              I have the same problem with chaos cosmos here on Vray with Rhino. It appears that the problem disappears after reinstalling the cosmos app. However, it works only once. After I shut down my PC and then turn it on again I have to reinstall the app again in order to make it work. Does anybody have a long-lasting solution for this?
              Runnning cosmos_250942_win_x64 with vray_52004_rhino_win_x64 on Rhino 6 latest build.
              Edit
              checking all the boxes for firewall settings of all the vray apps seemed to resolve the issue.
              • #22
                In addition to my previous post, after updating the firewall settings, everything worked just fine, until I restarted the PC. Now my firewall has the same settings as before, but the Cosmos doesn't want to load again.. Any suggestions?
                • #23
                  Hey Hristiyan,
                  In this case it will be best if you can send us the cb.log located in C:\Program Files\Common Files\ChaosGroup\ChaosCosmos\ so we can analyze the root cause of the issue.
                  Please submit a support request through here - > https://support.chaos.com/hc/en-us/requests/new and attach the cb.log so we can help you better.
                  • #24
                    Originally posted by borislav.stefanov View Post
                    Hey Hristiyan,
                    Hey Borislav,
                    Thank you, for your suggestion. I just sent you the requested file with a short explanation. I look forward to read from you soon!
                    • #25
                      Hi There,
                      Same problem with the cosmos. It was functioning well previously and then it simply will not allow me to even sign in.
                      Using Sketchup 2019 and 2022 on Macbook.
                      • #26
                        Did anyone ever get the solution with the Cosmos browser problems?
