Fading in Objects in Vantage ?
  • Fading in Objects in Vantage ?
    Afternoon.
    I have a Master Plan site Model,
    want to animate and fade in the different Phases as It rotates.
    Normally I would adjust the properties from 0 to 1.
    But iI don't seem to have that option in Vantage.
    Can somebody advise on how to do this please.
    Thank you
    Phil
    Hi, thanks for posting. Could you give us a visual example of what you are trying to do? Are you using Live Link? Are you using 3ds Max?
    Vladimir Krastev | chaos.com
      Yes, I am using live link.
      So literally, fade an object from nothing to Visible over 50 frames. Nothing fancy.
        Hi, this improvement idea is already logged in our system under LAV-1163. As of now Vantage reads the visibility only as "0" or as "1" and the plan is to improve this so we can render the whole range for a smooth fading effect. Please check this thread as well.
          Yes that's what I have found, fully visible of nothing.
          So I could render it with Refraction turned down but the blocka always reflect inside, so What setting do i use to get a just plane block, and not a glass one, if you get my meaning.
            Hi, if you set your material's IOR to 1 it should work.
              Vladimir
              Thank you
              Phil
