Some extra Lavina bugs after testing
  • Some extra Lavina bugs after testing
    Today for the first time we used Lavina in a workflow for a cliënt to test it in our production phase and below some extra bugs we noticed:
    -Reload Scene sometimes reset changed lights in lavina
    -camera eye height option doesn't work
    -Instance vray lights not working
    -Rotating group uses wrong pivot point
    -Curtains with semi transparency blocks sunlights from HDRI
    -Layer structure would be nice, we now solved it by making groups for keeping the object list as clean as possible.
    -Disc lights get converted to rectangular
    -Denoising of glass gives black spots
    -No denoising in save image with imagesaver (not screenshot)
    -Fast switching of quality levels would be great. For example one is with low settings for walking around, the other is for quick rendering, the last is for production rendering.
    -If in vray override material is switched on, it can't be switched off in Lavina.
    But nevertheless regarding the phase it's in (Beta 0.1) it's amazing and for us it would be the one that kills them all (Lumion, Twinmotion), because it integrates seamlesly with our workflow.
    Are the curtains using a 2-sided material, or do you mean something else by "transparency" ?
    This is on the TODO list.
    What kind of control would you need over what gets included in these "presets" or "quality levels".
    Should it be just all the options that affect the rendering algorithm ?
    This is unfortunately unavoidable for now. When you switch on the "override" material in 3ds Max, the rest of the materials are no longer part of the .vrscene file.
    The override material is applied on everything.
    We would have to change how the override material works in V-Ray Standalone and modify the V-Ray for 3ds Max export, and only then we can fix Lavina to recognize this new override material.
    Greetings,
    Vladimir Nedev
      The sunlight itself get's cut off (transparancy), so you don't get softer sunlight but no sunlight at all through the curtains. The GI is correct, but the sunlight passing through isn't.
      Just some simple buttons (3 or so) to quick click to several quality levels. Maybe even possible to set the quality leves ourselves. So that walking throug a big project is smoother when navigating and if more quality is needed i can be switched on the fly.
      No problemo, as said before, it is already a amazing viewer!
      Kind regards,
      Christian Wauben
      XR group
        Changes would only work if you saved a vrdx ("config") file. Is that the case? It is auto-loaded with the scene if it has the same name (the default save config name).
        It only works while collision detection is turned on. I'm not sure how sensible it would be when the camera is free and could be flying everywhere.
        Pivot points are not exported as part of the vrscene. We are aware of the issue. We need to change our exporters for this.
        Could you share a screenshot? Denoising refractive objects has some limitations.
        Not sure what you meant by "imagesaver". Was it File->Save Image or something else?
        Nikola Goranov
        Chaos Developer
          I am sorry, I am still not sure what might be wrong.
          Can you get me an example scene ?
          It will help me fix it.
          Greetings,
          Vladimir Nedev
            Yes this is the case but sometimes the changes are erased in the file (opened it in an editor and saw that the last line with the changes dissapeared).
            We indeed used the flythrough mode. Maybe greying out is an idea when using this mode so it's users don't get confused?
            So this is a vray update and not a Lavina update?
            See attached
            I just noticed that this was incorrect, it is working but we deactivated it because of the problem with the glass. My bad.
            So just ignore this line in the bugreport.
              Greetings,
              Vladimir Nedev
              Hmmm....strangly enough i just made a new simple scene with a curtain and a falloff map in the refraction and in this scene it is working. So maybe there is something wrong with the scene of my colleague. I will try to discover what is wrong next monday when I'm back at the office. For now just ignore this bug, it seems that it's a fault on our side.
                For reference i thought that this wasn't working with the curtains (the shadows trough the curtain material) like in this example.
                Is there a list for reference what shows which maps and materials can be used and which not? Like falloff, composite, doublesided and vraymtl, vraylightmtl and so on.
                  ```Pivot points are not exported as part of the vrscene. We are aware of the issue. We need to change our exporters for this.```
                  It has to be implemented on both sides, yes.
                  Actually, this shouldn't be working.
                  The performance of shadow rays is very critical.
                  For this reason, our "shading graph" system is not used for opacity maps and when calculating the transparency of a material for shadow rays due to refraction (when "affect shadows" is enabled on the material).
                  Instead, only file bitmaps are supported in these two cases.
                  So, the falloff texture won't work.
                  Not sure why it does what you want in one case and not the other.
                  Simple example scenes with both the working and not working version will help me understand what's going on exactly.
                  We have a compatibility page here in our docs site : https://docs.chaosgroup.com/display/...orted+Features
                  We are going to update it as we release new builds with more supported features.
                  Greetings,
                  Vladimir Nedev
