Yeah I should have clarified - if you're considering upgrading, you'd need to upgrade the GPU as well. You need an RTX series card. (Technically it would also run on the Pascal generation, but it is below our minimum requirements).
A K4000 is the Kepler generation of GPU - which is now over 6.5 years old.
This generation of card is not supported by Vantage, nor is it supported with V-Ray GPU.
