d3d12.dll is missing - program can't start
  • d3d12.dll is missing - program can't start
    Hi there
    I assume my graphics card (Quadro K4000) can't handle Vantage? It only supports DirectX version 11?
    Visit my blog: http://philipnel77.wix.com/raywire
    DirectX 12 is part of Windows 10. Are you on an older version of Windows? You can see the requirements here: https://docs.chaosgroup.com/display/...m+Requirements
    Nikola Goranov
    Chaos Developer
      Oh yes, I'm still on Windows 7 - I suppose I just can't download that specific dll somewhere? It's never as easy as that, right?!
        Nope, sorry. Vantage works on Windows 10 only.
        Nikola Goranov
        Chaos Developer
          Ok, Thanks!
            Even if you had Win10 Philip, you're not going to get much out of that GPU, it's a bit old and only 3GB ram
            Kind Regards,
            Morne
              Yeah I should have clarified - if you're considering upgrading, you'd need to upgrade the GPU as well. You need an RTX series card. (Technically it would also run on the Pascal generation, but it is below our minimum requirements).
              Nikola Goranov
              Chaos Developer
                A K4000 is the Kepler generation of GPU - which is now over 6.5 years old.
                This generation of card is not supported by Vantage, nor is it supported with V-Ray GPU.
                Kind regards,
                - Phil
                - Phil
                VP Product Management, Chaos Group
