Vantage and CG-Source Multi texture
  • Vantage and CG-Source Multi texture
    Having issues when trying to use CG-Source Multi-tex. I read somewhere that this should be implemented in Vantage now. Any suggestions or tips??
    Hi tom_spall,
    Yes, Multi-Tex is supported. What type of issues are you having? Can you send a screenshot or scene that we can take a look at?
    Alexander
    Alexander Atanasov
    Chaos
          Hi Tom,
          I am unable to reproduce the issue, it works fine on my end: https://drive.google.com/uc?id=1UBsn...2IJn9X_T5LEswu
          Which version of V-Ray are you using? Can you please send the scene using the form here: https://support.chaos.com/hc so we can investigate?
          Alexander
          Alexander Atanasov
          Chaos
            Oh, that's weird. I'm using vray 2.3 (5.20.23 build 00001) and Vantage 1.7.4. Do I need to update anything? Also, running RTX 3070
              No, those should be fine. You needn't update anything. Perhaps the files are not accessible by Vantage or you have applied an global override material inside Max or enable the Material Override in Vantage()https://docs.chaos.com/display/LAV/Materials+tab?
              Alexander
              Alexander Atanasov
              Chaos
                Ok, I had the same problem, and it's got nothing to do with material override.
                What worked with me was to lower the texture resolution. The CG textures I was using were plank of 46k pixels long.
                I resized it and it worked. (to 12k pixels)
                Side note, it seem that you need to force Vantage to refresh your material.
                If you just resize it in Ps, Reload in Max, it will not work in Vantage.
                What I had to do was to pick another texture, wait for Vantage to display it, and then re-pick the texture I just resized.
                I'm using a 3090Rtx, it's not because of the GPU.
                Hope it will help someone and save the time I spent troubleshooting this !
                  I forgot...Multitexture got nothing to do with the fact that the texture doesn't show up in Vantage.
                  It's the texture by itself that cause the problem in my case.
                  But I think that textures that resolution are not used in our workflow except when using CG texture flooring inside Multitexture.
                    Vantage is built on DirectX where the maximum texture size is 16384x16384.
                    Nikola Goranov
                    Chaos Developer
