Double the consumption of physical memory?
  • Double the consumption of physical memory?
    I found that after I opened a scene, my physical memory occupied 20GB. At this time, if I enabled real-time link, my physical memory occupation continued to increase until 35gb, and the memory of the graphics card also increased. In my opinion, after real-time linkage, shouldn't it just occupy the memory of the graphics card. Why physical memory usage has also increased. It's like vraycpu rendering.
    At some time, if my memory is full, it may also affect the real-time link of vantage, resulting in loading failure. But that scene only occupies 13gb of graphics card memory, which has not exceeded my 3090 maximum graphics card memory. Why does some content occupy physical memory when enabling real-time link? What is it?
    I assume that you mean that opening the scene in 3ds Max takes up 20GB of CPU RAM (together with other system processes). This is memory used by 3ds Max and we have no control over it. When you start the link Vantage has to receive the whole scene in "V-Ray format", so the data is duplicated in a way. This is inevitable. It's a known downside of live link (RAM usage will be much lower if you can work directly with a vrscene file, but that's a different workflow). Vantage needs to hold most of the data in CPU RAM so it doesn't release it after uploading to the GPU.
    Nikola Goranov
    Chaos Developer
      I see. No wonder after using vantage real-time link, I felt the unprecedented memory utilization.Is this a problem that cannot be optimized? If so Maybe I should upgrade my physical memory
      If I turn a large number of models into Vray proxy objects in the scene, can I reduce the consumption of graphics card memory and physical memory?. Will it dynamically load and unload Vray agents? Just like vraycpu
        No, we don't do that, Vantage aims to be a real-time not an offline renderer.
        How much RAM do you have ?
        Greetings,
        Vladimir Nedev
          Greetings,
          Vladimir Nedev
          I have 64GB memory
            After loading the scene, Vantage needs to keep textures and geometry in CPU memory so they can be quickly uploaded to the GPU memory when needed.
            If we had to go back to the file system and read them, that would be very slow.
            With the upcoming dynamic textures, texture mip maps are loaded and unloaded from the GPU as you move the camera or move objects in the scene,
            so it's even more important to have them in CPU memory for a quick upload to GPU memory.
            In the future, we might enable texture compression and this will reduce the required CPU memory somewhat.
            Can't say when this will happen.
            Greetings,
            Vladimir Nedev
              Update 1.8.0 was just released so users can already try this.
              Nikola Goranov
              Chaos Developer
                I have started to try it. Great features,
                However, I have a suggestion that the current Vantage cloud system can only be used in vraysky,Otherwise, its UI is not visible, and I suggest that it can also be used when 3dsamx uses vraydome to load HDR. Because there are many clouds in HDR, but there was no way to simulate the shadow cast by HDR clouds before. If you allow it to be used in this mode now. Then I will be able to use the cloud system to simulate the shadow of HDR mapped clouds. Then add whether the system cloud is visible, so that the shadows cast by the ground can be preserved separately
                In addition,because I don't use vray6, so Whenever I set parameters for vraysun or move it,Or when moving the timeline, vantage's cloud system is automatically reset and cancelled. Can I not automatically link its parameters for versions below vray6, because vray5 does not have this parameter. So it will be reset.
                Now I must carefully set up vantage cloud system and prohibit any vraysun operation.And prohibit the switching of the timeline (this obviously cannot be prohibited) This is very inconvenient
                  Greetings,
                  Vladimir Nedev
                  I see, thank you
                    Greetings,
                    Vladimir Nedev
                    I will open a topic for it alone to discuss it
                    I tried 1.8 I have some questions and suggestions
                    1:
                    I have a suggestion that the current Vantage cloud system can only be used in vraysky,Otherwise, its UI is not visible, and I suggest that it can also be used when 3dsmax uses vraydome to load HDR. Because there are many clouds in HDR, but there was no way to simulate the shadow cast by HDR clouds before. If you allow it to be used in this mode now. Then I will be able to use the cloud system to simulate the shadow of HDR mapped clouds. Then add whether the system cloud is visible, so that the shadows cast by the ground can be preserved separately
                    2:Please put the Exposure bias UI and other color matching UI together
                    3:Is it considered to further increase curve tinting?
                    4:I tried to load dynamic maps (IFL files) under real-time links, but failed. Whether to use standard bitmap or vraybitmap?Maybe my operation is incorrect?
                    5:ynamic loading of bitmaps has been tested, reducing my scene, which originally required 14g of display memory, to 8g. This is an excellent function, but during the test, my vantage appeared a question about BMP error. At present, I haven't caught the reason. This is my test scenario. I use it for testing in different versions. This is the first time that this prompt appears.
                    6:I didn't find the information about min term under enable ray termination Prob and max.prob. Their descriptions are not found, and their values do not need to be adjusted?
                    7:(Experimental option to increase FPS by decreasing sampling quality)What is the difference between the sample parameters here and the sample limit under advanced scene settings? If it's the same, why don't you read the value here directly? When it reaches it, it will automatically pause, and now it is allowed to set samples in both places
                      You should probably have started separate forum threads for each of these issues. Anyway:
                      You should generally always use the VRayBitmap.
                      I think there is an update issue in live link with IFL files when you use the standard bitmap. I believe it happens with V-Ray GPU too.
                      Can you show a screen shot of this error ?
                      We've left them there since the whole feature is experimental.
                      You shouldn't change the min termination probability, as this can lead to noise that never clears.
                      If you decrease the max termination probability, less rays will be terminated, so FPS will be lower, but there will be less additional noise caused by the ray termination option.
                      I don't think this question is related to the "Experimental option to increase FPS by decreasing sampling quality" ?
                      What do you mean by the "sample" parameter "here" ?
                      Greetings,
                      Vladimir Nedev
                        Sorry, I did a simple test, so I didn't create a new thread for it. I will pay attention to this later.
                        I tested standard bitmap and vraybitmap, but they failed. I'll try again tomorrow
                        Latest news:(I found the problem. Use vraybitmap to load dynamic maps. If the map file name contains Japanese, Chinese, Korean, the animation sequence will fail to load.)
                        If it appears next time, I will keep the screenshot
                        I see. Thank you
                        Will this function have an effect when rendering sequences? For example, if you open it, you will get faster rendering speed when rendering images and videos.
                        Or does it only take effect during preview in order to improve FPS during operation
                        Sorry, I'm wrong. I'm talking about the function of automatically pausing rendering after reaching the sampling sample.(Option to pause rendering after reaching a certain sample level.)
                        Can cloud system optimization be implemented? Otherwise, it is almost unavailable under vray5. At the same time, it would be great if it could be used to simulate the cloud shadow of HDR
                          Could you clarify this question: are you asking about the Advanced Scene Settings dialog? There are no relevant sampling settings there. Or are you referring to the noise threshold setting? Or something else? The noise threshold setting lets the render engine skip the pixels which are "done" according to this value. But it will not stop the renderer. Even if all the pixels have reached the threshold, the renderer will keep iterating (therefore keeping your GPU busy) unless it gets paused for some other reason.
                          Nikola Goranov
                          Chaos Developer
                            Yes, I checked the help document again later and understood this problem. Thank you.At first, I thought they were the same parameters. Later, I learned its principle. As you said, only one parameter will affect whether vantage's GPU continues to calculate when it reaches the threshold
                            (I initially thought that sample limit and stop interactive sample were the same, so I also considered whether they need to be set with the same value.)
                            The design of cloud system is very good. I can imagine that it can bring richer picture effects, so I tested it again today, hoping to consider the situation I explained. Let users of vray5 be able to use it under real-time linkage, and do not hide the UI of the cloud system when using HDR, and add a cloud camera to be visible,This allows you to simulate only cloud shadows when needed
                              It Still Doesn't work for me. I have used VrayBitmap with a vraymtl and a jpeg sequence without any Japanese, Chinese, Korean, letters and then started a live link. Also the 'update image sequence for current frame' button doesnt work. Am I doing something wrong? I use Vray 6 + 3ds max 2023.
