The rendering is different from the screen
  • The rendering is different from the screen
    just a little test of Vantage 1.8.2 with a .vrscene from V-Ray 6 for Sketchup.
    Why such a difference between the final render (too dark) and the Vantage view.
    I'm new to Vantage, maybe I'm not doing it right.
    Thank you.
    Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
    Sketchup PRO 24.0.594 + V-Ray 6.20.05
    3DS Max 2024.2.3 + V-Ray 6.20.06
    Chaos Vantage 2.5.1
    GeForce Studio Ready Driver Version 551.86​
    Hi DCHA34,
    Have you enabled the Auto-exposure in Vantage or have color correction made in the VFB(color correction layers are not supported from vrscenes in Vantage)?
    Alexander
    Alexander Atanasov
    Chaos
      I forgot to mention: the file on the left is the Vantage rendering, not the V-Ray one.
      And yes, AutoExposure is enabled in Vantage.​
      And Filmic Tonemap AMPAS is also activated with default settings.
      Chaos Vantage 2.5.1
        Is it enabled for both viewport and checked in the Render setup dialog? https://drive.google.com/uc?id=1p2ff...aPQ-YAVNLHttP1
        Alexander Atanasov
        Chaos
          yes, it is checked.
          Chaos Vantage 2.5.1
            I think the differences in the render resolutions (viewport and offline) is what is causing the brightness difference when using the Auto exposure. Can you set the viewport/camera resolution to be the same as the final render resolution(or vise versa) and see if the issue persists? We will investigate it as well.
            Alexander
            Alexander Atanasov
            Chaos
              You are right, the problem is the difference in resolution.
              My screen is a 2K :
              - rendered in 4k = problem
              - rendered in 2K = identical image
              You'll have to get your hands in the code and fix it.​
              Chaos Vantage 2.5.1
                We fixed the issue, but 1.8.3 is already released, so the fix will be added to the next update.
                Nikola Goranov
                Chaos Developer
