The rendering is different from the screen
I forgot to mention: the file on the left is the Vantage rendering, not the V-Ray one.
And yes, AutoExposure is enabled in Vantage.
And Filmic Tonemap AMPAS is also activated with default settings.Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
Sketchup PRO 24.0.594 + V-Ray 6.20.05
3DS Max 2024.2.3 + V-Ray 6.20.06
Chaos Vantage 2.5.1
GeForce Studio Ready Driver Version 551.86
Is it enabled for both viewport and checked in the Render setup dialog? https://drive.google.com/uc?id=1p2ff...aPQ-YAVNLHttP1Alexander Atanasov
Chaos
I think the differences in the render resolutions (viewport and offline) is what is causing the brightness difference when using the Auto exposure. Can you set the viewport/camera resolution to be the same as the final render resolution(or vise versa) and see if the issue persists? We will investigate it as well.
AlexanderAlexander Atanasov
Chaos
You are right, the problem is the difference in resolution.
My screen is a 2K :
- rendered in 4k = problem
- rendered in 2K = identical image
You'll have to get your hands in the code and fix it.Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
Chaos Vantage 2.5.1
