Originally posted by vladimir.nedev
View Post
Update 1.8.5 and LiveLink
I downgraded to Vray version 6.10.04 and the same frame rendering issue was resolved, I used vantage 1.8.5
Are you still on 6.10.04 ?
I also had twice problems with crashes in the middle of rendering an animation.
Did you have such crashes before 1.8.5 ?
Greetings,
Vladimir Nedev
Originally posted by pablo_vinicius View PostI downgraded to Vray version 6.10.04 and the same frame rendering issue was resolved, I used vantage 1.8.5
Probably the problem is in vray version 6.10.06, which also seems to be slower to start the link and send the geometry to vantage.
Vantage 1.8.5 is working, but I still have problems with crashes, example: sometimes when the livelink is started, Vantage crashes at the time of "Scene Ready"
Not sure if it's the same reason,
and sometimes it will crash when Vantage displays "Scene Ready".Last edited by q976431; 26-04-2023, 08:18 PM.
Originally posted by vladimir.nedev View Post
Did this really get resolved or maybe it happens randomly ?
Are these still happening ?
Greetings,
Vladimir Nedev
I did more tests and the crash problem was completely solved after correcting Cosmos, but I still have the duplicate frame problem in vantage version 1.8.5
At first I thought it was a problem with the V-ray version, but I updated v-ray to version 6.10.06 and the problem only happens with vantage 1.8.5.
I made some sample screen recordings, you can see that in vantage 1.8.5 the frame advances and then rewinds.
https://drive.google.com/drive/folde...usp=share_link
Greetings,
Vladimir Nedev
Can you try opening the following file in an editor (in administrator) mode:
C:\Program Files\Chaos Group\Vantage\dcc_scripts\3dsMax\Vantage-LiveLink.ms
and delete the following line
vr.ipr_useRenderState = true
Then save the file.
You will have to restart 3dsMax for the change to take effect.
After that try again if the live link starts working as expected.
Greetings,
Vladimir Nedev
The files seem to work a little better bat still have some kind of lag in the UI
Hi mirko_pignotti,
Could you share the scene to try and reproduce the issue on our end? You can submit it here with a link to this thread https://support.chaos.com/hc/en-us/requests/new and when we receive and examine it we will report back.
AlexanderAlexander Atanasov
Chaos
Alexander
Apparently, the problem was in Vray:
I've updated it to 6.1.2,
then I noticed that the light cash was taking an infinite time to calculate
So I've just switched the engine to Arnold and then to VrayGpu again,
this should have reset the Vray setup, and the problem is solved!
I wish I'd answered earlier...
Anyway, I've saved a backup of the "corrupted scene" if you want to examine it.
Thank you!
