Noise after first rendered frame
  • Noise after first rendered frame
    I keep noticing this in the 2.2.1 build:
    Happens randomly where the first frame renders fine then its like the denoiser drops out from there. This is with denoise on end and reduce flickering/interpolation both on.
    See attached. I literally aborted that sequence then ran it again and it didn't produce the same artifacts after the first frame. Running on nvidia driver 546.01
    It's happened on a number of different scenes and not exclusive to the one above
      Are you rendering the animation through the live link or from a vrscene file ?
      Greetings,
      Vladimir Nedev
        Vrscene file
          Hi rusteberg,
          Can you share the scene and the render settings so we can test it on our end? You can use the Chaos Help form with a link to the forum thread: https://support.chaos.com/hc/en-us/requests/new. You will have to include all asset files. Once we have the scene and do some testing we will write back.
          Alexander
          Alexander Atanasov
          Chaos
            I'll try to put something together today.....
            On a related note, would it be possible to implement a "pack and go", asset collection tool within Vantage?
              Hi rusteberg,
              The package scene functionality is already logged in our system under LAV-498. I will try to raise its priority.
              Alexander
              Alexander Atanasov
              Chaos
                Thanks Alexander. Just submitted that through help form. Ticket ID 195838
                  It seems the issue is caused by the "Only final pass" denoiser option. Try rendering without it.
                  Nikola Goranov
                  Chaos Developer
                    When using Live Link, this occurs when starting rendering from viewport №2 in 3dsMax.
                    Team Vantage, do it tests.​
                      I've had this problem many times through livelink, hence I'll never render animations in particular through livelink, there is no rhyme or reason for it.
                      Jason
                      AMD Threadripper 3990x 64C Processor, 128 GB DDR4-3200 Ram, 48 GB PNY Quadro RTX A6000, ​Windows Pro 10.0.19045.4894, 3dsmax 2025.3, Vray 62006, Vantage 2.5.2​
                        Hi, rusteberg​. What version 3dsMax are you using?
