could be great and very useful to have a specific Vantage compatible material library in "Vray material library browser"
It will be easier for us to just support as much of the normal material library as possible.
That's what I think at least.
Greetings,
Vladimir Nedev
Can you point to specific issues that you have with the materials from the library when using them in Vantage ?
Greetings,
Vladimir Nedev
Originally posted by eric_barbaron View PostHi Vladimir,
for example, a vraymtl with composite of several layers as diffuse map appears in vantage a single map...It doesn't display the all layers of the composite in reflexion
Instead, Vantage uses a simplified texture, as calculating the real shading graph can be much slower (up to 2 times or maybe even more depending on the graph).
We might want to revise the condition when shading graphs are disabled - for example do it only for reflection glossiness < some value.
So if you could send us the scene, it might be helpful in determining the best approach.
See screenshot for how you can enable shading graphs for GI/glossy rays.
Greetings,
Vladimir Nedev1 PhotoLast edited by vladimir.nedev; 23-04-2021, 04:48 AM.Vantage developer, e-mail: vladimir.nedev@chaos.com , for licensing problems please contact : chaos.com/help
