URGENT! NO ACTIVE PRODUCTS?????? Gui License error (-200): -200: The Chaos License Server could not be reached.
  • URGENT! NO ACTIVE PRODUCTS?????? Gui License error (-200): -200: The Chaos License Server could not be reached.
    I don't use 3DS Max much these days but I've got an urgent request to create a render, yet when I fired up 3DS Max 2023 (or 2022) I have issues with vRay licensing......
    I am getting nothing on the page http://localhost:30304/#/ when I try to open it in my browser.
    I then go to to take a look at my products at my.chaos.com and I get a page saying "Oops something went wrong - we couldn't load your products".
    Can anyone on here help?
    Thank you.
    Click image for larger version  Name:	Screenshot 2023-03-10 145412.jpg Views:	0 Size:	143.1 KB ID:	1175202
    Click image for larger version  Name:	Screenshot 2023-03-10 145256.jpg Views:	0 Size:	151.1 KB ID:	1175203
    Jez
    3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
    Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
    Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
    ---- Updated 06/09/23 -------
    Okay, I've gotten it to work (for now!) - but I think the VRLService needs to be started automatically each time I restart my computer, but currently I'm having to and double-click on C:\Program Files\Chaos\VRLService\start.bat
    How can I set this up so that I don't have to start the service manually?
    Thanks.
    Jez
      Hello Jez,
      If you have urgent issues that need to be addressed as quickly as possible by the Chaos support, please open an official ticket via our Help Center here.
      The Chaos license server requires Windows to be able to generate its UUID (Universally unique identifier) in order to work. If Windows cannot generate its UUID the Chaos license server will not be able to start. It seems like the problem stems from there
      Please check if your OS can generate the UUID, open Command Prompt (CMD) and use the following command wmic csproduct get UUID
      If Windows cannot generate the UUID, please open Command Prompt with Administrator privileges and use the commands listed in the following article one after the other:
      https://support.chaos.com/hc/en-us/a...erate-its-UUID
      Reinstall the Chaos license server afterwards and try to access http://localhost:30304. If this doesn't help or Windows can generate the UUID but the issue is still present, please open a ticket so that we can contact you directly. You can download the server from the following link
      Nikolay Simeonov
      support@chaosgroup.com
      Chaos Group
        Hello,
        The Chaos license server before version 6.0 was working as a service. Since we released version 6, the Chaos license server is working as a process which should automatically start once you log in Windows.
        If you are using Chaos license server version 6, please add it in your Windows Startup apps:
        https://www.makeuseof.com/how-to-add...ms-windows-11/
        Nikolay Simeonov
        Chaos Group
          Originally posted by nikolay.simeonov View Post
          Hello,
          Hi Nikolay,
          Thank you for your assistance.
          I'll try this now and let you know how I get on.
          Many thanks.
          Jez
            Hi Nikolay,
            It has now worked, what I did was create a shortcut to C:\Program Files\Chaos\VRLService\start.bat that seems to have done it - would you say that's the best way?
            Jez
              For version 6 the best way would be the one suggested by Nikolay, to make sure that Chaos License Server Supervisor is enabled in Winodws's Startup Apps.
              Kostadin Botev
              Contact Support
              Chaos
                Hi Kostadin,
                I don't have the Chaos License Server Supervisor in Window's Startup App, its missing from there (see attached)....
Name:	Screenshot 2023-03-13 135925.jpg
                Jez
                  How can I get rid of this Command Prompt dialog box on startup?
Name:	Screenshot 2023-03-13 144535.jpg
                  I have this shortcut here;
Name:	Screenshot 2023-03-13 144744.jpg
                  And this is what's in the start.bat file;
Name:	Screenshot 2023-03-13 145535.jpg
                  Jez
                    The bath file should work just fine for you, its strange that you don't have the supervisor at all in startup apps. Perhaps a re install of the license server will do the trick but if its working for you like this I'm not sure that's really needed. Regarding the command prompt that refuses to disappear check that thread:
                    https://forums.chaos.com/forum/licen...ws-on-start-up
                    Kostadin Botev
                    Contact Support
                    Chaos
