RT render failing after each frame in backburner with Max 2019
    Just to add to this to help anyone in future. It's some sort of bug in the 3ds max ribbon interface and the precursor is usually seeing ribbon interface items briefly appear over your desktop as a node is loading 3ds max.
    Deleting the ENU folder fixes this, but it is the nuclear option. You end up losing your custom macros, shortcut keys, all installed scripts and custom toolbar buttons
    Through a lot of trial and error I narrowed it down to this file being the culprit:
    Workspace1__usersave__.ribbonconfig.xaml
    Located in:
    \AppData\Local\Autodesk\3dsMax\2020 - 64bit\ENU\en-US\UI\Workspaces\usersave
    Deleting or just renaming the extension to something else fixed the issue for me as Max then reverts to the default ribbon config file.
    All custom user interface items remain intact also.
    Really wish Autodesk would fix this.
      Located in:
      It's been a while since you posted this but just a quick thank you for posting it. Worked like a charm and saved me having to restore all of the scripts, settings, etc.
        Located in:
        Yes this also was my issue. It clicked when I read your suggestion, but also noticed that when the issue began, an expanded ribbon menu appeared out of nowhere during BB sessions.
