Problem with molotow-cocktail - liquid through wall
  • #31
    nevertheless we have to find the reason for this behavior
    ______________________________________________
    VRScans developer
    • #32
      Second that. Shall I give you the scene?
      • #33
        first we will try to reproduce it
        VRScans developer
        • #34
          Ivaylo!
          Were you able to reproduce this behavior?
          Sascha
          • #35
            not yet, but we didn't try it, just scheduled.
            VRScans developer
            • #36
              Yeah, okay, if I have problems with that issue, I will report them. I have to do several more playspeed-animations due to a bullet-time-shot with 4 simulators...
              • #37
                Ivaylo!
                An idea: wouldn´t it be great to have some proxy-functionality? My scene has now several sims with multi-million cells - an animating the scene is a real pain! If there was a possibility to use proxy-sims just for the viewport-display - with waaay downscaled resolution for the grid - that would be incredible!
                It might be even possible to take the high-res-simulation to generate a low-res-version from that. So you have to simulate only once.
                In the output-module there could be a "Generate proxy" option with half/third/quater/eighth settings - generating a similar named output with "proxy_half" suffix or something...
                ...and in the input there might be the usual proxy-functionality - "Use proxy" - "Choose proxy" - "use for rendering", etc.
                What do you think?
                Sascha
                • #38
                  yes, this feature is already discussed, and it will be implemented. of course not a different file, just a small copy in the same file.
                  VRScans developer
                  • #39
                    Cool.
                    But doesn´t that mean that the whole file has to be loaded? With a sim with 80MB per frame - nearly 2Gigs/s @ 24fps the - HDD is the bottleneck - LAN is much worse. With several simulators of that size it gets horrible...
                    • #40
                      yes, the main idea is to skip the loading, because it is slow for large sims, even if no further processing is carried out
                      VRScans developer
                      • #41
                        So only a fragment of the *.aur-file has to be loaded?
                        • #42
                          yes, this is technically no problem. now even if you have reduced preview, it loads and uncompresses the entire data, that is slow.
                          VRScans developer
                          • #43
                            Problem with Anim Index
                            Ivaylo!
                            Aaaargh, so here I have the problem with changing the playspeed again! Remember?
                            Here is a preview of my scene:
                            You see that there are jerks and jumps in the sim.
                            I animated the Anim Index - but at the moment it does no changes -I have a stright line from -100/-100 to 2000/2000 - what means that I do not have any timechange at the moment - but the jerks happen...
                            This makes my blood freeze - I have to deliver end of february!
                            Heeeeelp.....
                            • #44
                              I hoped that it would not happen on render, but here is the renderresult:
                              It´s even worse! The anim is really jerky!
                              AAAARGH!
                              What do you think could be the problem?
                              • I have sims starting at -100
                              • I have multiple sims with different sim-start-stopframes (I just deleted all except one - no changes)
                              • I set the playspeed to 0 and use only the anim index (tried this, doesn´t change)
                              • I also reduced the simulation-speed (not playspeed)
                              • Max 2012
                              Wow, I really need a solution for this or I really get in trouble!
                              Do you have any ideas for fixing / workaround?
                              I´ll try to reproduce it with a simple scene...
                              Thank you Ivaylo!
                              • #45
                                Doesn´t the Anim Index use blending? Only the Play speed?
                                I cannot reproduce. Could it be that these may be frames where I paused the sim to testrender or to render a preview? Or maybe restoring? I did this several times, especially when max crahsed....
