Suggestions on how to make a proper shockwave over water?
  • Suggestions on how to make a proper shockwave over water?
    Hello Everyone,
    I'm new to Phoenix, love the product but running into some simulation challenges.
    I'm trying to simulate the shockwave of a big battleship gun firing. It creates a quick shockwave as the gasses dissipate.
    I tried using an animated sphere to deform the ocean, but it creates a heavy suction effect which I don't want so big. Is there a better way to achieve this effect or a few settings that you would recommend?
    Thank you in advance.
    Cyril
    Probably a quick blast of particles that die after one frame used as a velocity only source?
      Thank you, I will give that a try.
        Alternatively, if you want to use the sphere approach, try this:
        - Set the sphere as non-solid from its right click Phoenix properties
        - attach a source to it and disable all channels
        - enable Motion Velocity
        - regulate the multiplier - this will be the effect of the scaling sphere over the fluid
        Hope this helps
          Thank you that was helpful, just the trick I was looking for.
          Cheers!
          Cyril
