Error when GPU rendering
  • Error when GPU rendering
    Simple scene - Getting this issue. Tried restarting 3ds max and sometimes it works and starts rendering, other times it throws the same error.
    Dual 3090's are the cards
    [23:56:14.408] Error : [VUtils::gpuMemset32] 700: CUDA memset failed
    [23:56:14.470] Error : [MemoryManagerGpu::releaseUnmappedMemoryFromInstanc e] 700: Could not release device buffer
    [23:56:14.475] Error : [MemoryManagerGpu::releaseUnmappedMemoryFromInstanc e] 700: Could not release device buffer
    [23:56:15.916] Error : 33 error(s), 22 warning(s)
    It repeats the same error 33 times?
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      Hi spencerrayfitch
      I cannot reproduce this on my 2x 3090s, could you please try with my shaderball scene here
      Does it crash from you?
      What about the Benchmark tool?
      Error 700 could be about many things, including drivers or hardware issues
      Are you on the latest recommended driver 512.59?
      Do you have NVlink enabled?
      Muhammed Hamed
      V-Ray GPU product specialist
      chaos.com
        Switching from RTX to CUDA (hybrid or C++/CPU device only) can cause crashes occasionally. If you switch engines, switch the engine to the desired one, save the scene and exit MAX. If this is the cause, restarting MAX is supposed to resolve this crash until we hotfix it.
        Deyan Ivanov
        V-Ray RT GPU Senior Developer
        Chaos Group
          Thank you for the comments. I will investigate these fixes this morning.
          I want to note that my other scenes with far more geo and textures etc render fine.
          No NVLink, and ill check driver.
            So I did this and it has seemed to resolve the issue at least for now.
              Originally posted by Muhammed_Hamed View Post
              Hi spencerrayfitch
              Thank you for the shaderball scene! I will give this a try!
                So i was rendering fine. Paused the render. Imported a model. The rendering stopped completely and when I tried to re-initialize the IPR - (Tried to upload the log as an attachment, wouldnt work)
                09:47:44.004] Warning : Using GPU device with display attached for rendering. UI might be sluggish.
                [09:47:44.009] Tiled texture cache set to 4000 MB
                [09:47:45.209] Warning : Export warnings:
                [09:47:45.213] Warning : Export problem for 'Map #11 (Bitmap)' (Exported bitmap e:\3d models\3d sky\black industiral windows\Textures\iron_bump.JPG with blur=0.10 will render differently!)
                [09:47:45.217] Warning : Affected Nodes: Industrial-Window005, Industrial-Window008, Industrial-Window006, Industrial-Window001, Industrial-Window007, Industrial-Window004
                [09:47:45.220] Warning : Affected Materials: metal-Black (VRayMtl), Industrial-Window1 (Multi/Sub-Object)
                [09:47:45.224] Warning : Export problem for 'Map #2138384047 (Bitmap)' (Exported bitmap e:\3d models\3d sky\industrial ceiling\industrial_ceiling\maps\Sparkles_1268.jpg with blur=0.10 will render differently!)
                [09:47:45.238] Warning : Affected Nodes: NYM_3Ñ…6_764, NYM_3Ñ…6_728, NYM_3Ñ…6_804, NYM_3Ñ…6_803, NYM_3Ñ…6_814, NYM_3Ñ…6_796, NYM_3Ñ…6_784, NYM_3Ñ…6_789, NYM_3Ñ…6_740, NYM_3Ñ…6_744, NYM_3Ñ…6_781, NYM_3Ñ…6_005, NYM_3Ñ…6_831, NYM_3Ñ…6_826, NYM_3Ñ…6_828, NYM_3Ñ…6_844, NYM_3Ñ…6_726, NYM_3Ñ…6_810, NYM_3Ñ…6_773, NYM_3Ñ…6_811, NYM_3Ñ…6_834, NYM_3Ñ…6_725, NYM_3Ñ…6_785, NYM_3Ñ…6_843, NYM_3Ñ…6_729, NYM_3Ñ…6_763, NYM_3Ñ…6_841, NYM_3Ñ…6_770, NYM_3Ñ…6_003, NYM_3Ñ…6_730, NYM_3Ñ…6_821, NYM_3Ñ…6_724, NYM_3Ñ…6_801, NYM_3Ñ…6_002, NYM_3Ñ…6_779, NYM_3Ñ…6_813, NYM_3Ñ…6_743, NYM_3Ñ…6_855, NYM_3Ñ…6_788, NYM_3Ñ…6_800, NYM_3Ñ…6_820, NYM_3Ñ…6_806, NYM_3Ñ…6_759, NYM_3Ñ…6_819, NYM_3Ñ…6_778, NYM_3Ñ…6_845, NYM_3Ñ…6_734, NYM_3Ñ…6_851, NYM_3Ñ…6_846, NYM_3Ñ…6_790, NYM_3Ñ…6_735, NYM_3Ñ…6_771, NYM_3Ñ…6_791, NYM_3Ñ…6_756, NYM_3Ñ…6_825, NYM_3Ñ…6_738, NYM_3Ñ…6_769, NYM_3Ñ…6_805, NYM_3Ñ…6_795, NYM_3Ñ…6_783, NYM_3Ñ…6_793, NYM_3Ñ…6_736, NYM_3Ñ…6_829, NYM_3Ñ…6_733, NYM_3Ñ…6_815, NYM_3Ñ…6_754, NYM_3Ñ…6_723, NYM_3Ñ…6_004, NYM_3Ñ…6_731, NYM_3Ñ…6_835, NYM_3Ñ…6_775, NYM_3Ñ…6_824, NYM_3Ñ…6_850, NYM_3Ñ…6_849, NYM_3Ñ…6_780, NYM_3Ñ…6_833, NYM_3Ñ…6_854, NYM_3Ñ…6_765, Object10432755, NYM_3Ñ…6_741, NYM_3Ñ…6_836, NYM_3Ñ…6_750, NYM_3Ñ…6_794, NYM_3Ñ…6_774, NYM_3Ñ…6_755, NYM_3Ñ…6_799, NYM_3Ñ…6_840, NYM_3Ñ…6_839, NYM_3Ñ…6_745, NYM_3Ñ…6_760, NYM_3Ñ…6_748, NYM_3Ñ…6_746, NYM_3Ñ…6_768, NYM_3Ñ…6_823, NYM_3Ñ…6_853, NYM_3Ñ…6_786, NYM_3Ñ…6_766, NYM_3Ñ…6_751, NYM_3Ñ…6_848, NYM_3Ñ…6_856, NYM_3Ñ…6_749, NYM_3Ñ…6_830, NYM_3Ñ…6_808, NYM_3Ñ…6_809, NYM_3Ñ…6_816, NYM_3Ñ…6_798, NYM_3Ñ…6_776, NYM_3Ñ…6_838, NYM_3Ñ…6_758, NYM_3Ñ…6_753, NYM_3Ñ…6_761, NYM_3Ñ…6_739, NYM_3Ñ…6_818
                [09:47:45.242] Warning : Affected Materials: CAC_HITACHI (Multi/Sub-Object), vray Gray_metall_1407 (VRayMtl)
                [09:47:45.245] Warning : Export problem for 'Map #13 (Bitmap)' (Exported bitmap e:\3d models\3d sky\industrial ceiling\industrial_ceiling\maps\stone_bump_1288.jp g with blur=0.10 will render differently!)
                [09:47:45.249] Warning : Affected Nodes: Pipe_3inch031, pipe_1inch_sprinkler_coner_032, Support_G_400_247, Support_G_400_250, Support_G_400_245, Object10432395, Object10432392, Object10432397, Object10432393, Cylinder6749, Object10432390, Cylinder6764, Object10432399, Support_G_400_244, Object10432391, Object10432402, Object10432401, Object10432400, Support_G_400_248, Object10432396, Object10432646, Support_G_400_223, Support_G_400_246, Support_G_400_243, Object10432398, Pipe_3inch036, Object10432394, Object10432755
                [09:47:45.252] Warning : Affected Materials: vray Bronze_1407 (VRayMtl), vray Sprinkler_body_steel_2002 (VRayMtl), CAC_HITACHI (Multi/Sub-Object), SPRINKLER_SYSTEM (Multi/Sub-Object), vray CAC_parts_Plastic_2002 (VRayMtl)
                [09:47:45.271] Warning : Export problem for 'Map #16 (Bitmap)' (Exported bitmap e:\3d models\bentajii\dives sofa maxv\scratches metalic fdewg.jpg with blur=0.01 will render differently!)
                [09:47:45.274] Warning : Affected Nodes: Box003, Box2131641467
                [09:47:45.278] Warning : Affected Materials: legs (VRayMtl)
                [09:47:45.281] Warning : Affected Textures: Map #15 (Color Correction), Map #15 (Falloff)
                [09:47:45.285] Warning : Export problem for 'Map #16 (Bitmap)' (Exported bitmap e:\3d models\bentajii\dives sofa maxv\scratches metalic fdewg.jpg with blur=0.01 will render differently!)
                [09:47:45.298] Warning : Affected Nodes: Box003, Box2131641467
                [09:47:45.301] Warning : Affected Materials: legs (VRayMtl)
                [09:47:45.305] Warning : Affected Textures: Map #15 (Color Correction)
                [09:47:45.308] Warning : Export problem for 'Map #12 (Bitmap)' (Exported bitmap e:\3d models\bentajii\dives sofa maxv\rope.jpg with blur=0.01 will render differently!)
                [09:47:45.314] Warning : Affected Nodes: Object10432768, Object014
                [09:47:45.328] Warning : Affected Materials: rope (VRayMtl)
                [09:47:45.832] Warning : Checking CUDA driver version: 5001: Installed driver version (512.96) is newer than the latest verified one (512.59)!
                [09:47:45.872] Warning : Error 700 while intializing context for device NVIDIA GeForce RTX 3090! Device will not be used for rendering!
                [09:47:45.875] Warning : Error 700 while intializing context for device NVIDIA GeForce RTX 3090! Device will not be used for rendering!
                [09:47:45.879] Warning : initDevices() failed. Please check that your system has compatible GPU devices installed.
                [09:47:45.883] Warning : Cancelling GPU rendering!
                [09:47:46.375] Warning : 0 error(s), 26 warning(s)
                  I think I have found the issue.
                  I was working on another computer yesterday, and some of the modeling I did had a varied version of the chamfer modifier. I was getting a warning error in my home version of 3ds max and i kinda ignored it. Since it kept popping up, i decided to collapse all of them and run a "Missing Plugin" script. So far testing has seemed successful.
                    Same issue happening.. Only way to fix it is to switch it to cuda, back to rtx, save the scene then close and reopen.
                      Error is getting too cumbersome to work with on this project. Having to revert back to 2022 and vray 5 - Hope this gets resolved.Seems like this is stemming from the latest build as i didnt have any issues 2 weeks ago.
                      Thanks.
                        Does that combination work for you?
                        Lele
                        Disclaimer:
                          Haven't had a problem since I reverted back. The scene has only gotten more complex also.
                            We are looking into this now, if you swap engines in V-Ray 5 you might crash as well. It is more frequent if you use bucket mode
                            Best,
                            Muhammed
                            Muhammed Hamed
                            chaos.com
                            • #15
                              Best,
                              Muhammed
                              Thank you for the info.... Do you know when this will be resolved? Id love to continue my testing of Vray 6 as we will want to deploy this at our studio when its ready!
