do they really need 3 separate posts in the general section about RT when this is here already?
V-Ray RT official announcement
I haven't seen it running on 16 physical cores yet, but it can keep the 16 logical cores of a dual i7 machine busy. CPU utilization is better on heavier scenes than for simple ones. There are also some settings that can be adjusted to give each CPU more work.
VladoI only act like I know everything, Rogers.
http://www.spot3d.com/vray/help/rt100/demolimits.htm
limited to time and only 15 objects, then it's impossible to test it on a real sceneis it really so slow that no one would buy it if they tried a scene with more objects?
I really hope this could be changed, why not just water mark it or something?
/Thomas
There's a dual i7 motherboard available? Or did you mean a type of Xeon?
Originally posted by suurland View Posthttp://www.spot3d.com/vray/help/rt100/demolimits.htm
/Thomas
Attaching multiple objects helps reduce their number.
Watermarking makes absolutely no sense in terms of protection.
-pm.Peter
...keep walking...
Originally posted by jujubee View PostThere's a dual i7 motherboard available? Or did you mean a type of Xeon?Peter
...keep walking...
/Thomas
will you have a student discount available
Originally posted by vlado View PostIt should be enough to help you get a clear idea of its capabilities. If it is not, I guess a limited evaluation license for the full version can be arranged if necessary, but this takes more time.
Originally posted by peter View Post15 objects are generally enough to test any scene and setup. In many cases people will get that much at all. Depends on what one does.
-pm.
Guess you are right about watermarking, but saying that people in many cases doesn't have more then 15 objects in their scene simply can't be right, right now I'm working a tiny project, and only been working on it for 5 hours and have 1200 objects, I can't think of a single scene I EVER made for production that has 15 objects or less.
/Thomas
Just attach them all if you want to see how well it handles it - you can see how fast it is and how well it handles a big scene, even if it is smashed into 10 objects and near impossible to actually work on beyond changing materials and moving basic elements.
You're not supposed to be able to use it for working on a scene though, otherwise people would never buy it.
Although you work on cars anyway suurland, object count is a bit different with what you do - i've had 250k poly 50 storey towers with 20 objects.
If you were into doing people, I imagine you wouldnt have a problem at all with 15 objects.Last edited by Neilg; 19-05-2009, 03:30 AM.
As long as performance isn't any different between attaching objects and keeping them separate, I suppose it is the same thing. I think we are all just curious to see how 'well' this performs before making a purchase. I can't blame people for being skeptical based on other software which promised similar functionality.
