so, if there are two artists and only one 8 core system as an extra render node, what happens when both users try to run activeshade at the same time using the same render node?
V-Ray RT official announcement
Originally posted by gunny263 View Postso, if there are two artists and only one 8 core system as an extra render node, what happens when both users try to run activeshade at the same time using the same render node?
VladoI only act like I know everything, Rogers.
Originally posted by suurland View Posthttp://www.spot3d.com/vray/help/rt100/demolimits.htm
limited to time and only 15 objects, then it's impossible to test it on a real sceneis it really so slow that no one would buy it if they tried a scene with more objects?
I really hope this could be changed, why not just water mark it or something?
/ThomasDmitry Vinnik
Silhouette Images Inc.
ShowReel:
Yes, but one mesh and 100 meshes with a lot of shaders, shadows, reflection is absolutely different.AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
2D | 3D | web | video
jiri.matys@gmail.com
https://gumroad.com/jirimatys
https://www.artstation.com/jiri_matys
https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
https://www.instagram.com/jiri.matys_cgi/
https://www.behance.net/Jiri_Matys
https://cz.linkedin.com/in/jiÅ™Ã-matys-195a41a0
From rendering point of view there isn't much of a difference between single mesh and multiple meshes. In the end they are generally combined into "single" mesh at render time anyway. Its slightly slower to have multiple object since you have to do transformation for every vertex in the mesh. However this overhead is so small it has very little effect on render times.
Instancing is a slightly different thing, I wonder if VRayRT handles instancing at all? Or does it just collapse them into single mesh at render time?
Originally posted by z1pp3r View Post48 minutes till tomorrow :P
