Information on V-Ray 2.0
This topic is closed.
question:
what´s the pricing policy to upgrade vray to 2.0 for those who use the educational versions? is it also 400 euro? (i purchased before august,1st 2010)
cheers
Would be best to email us to vray@chaosgroup.com for this information; I'm not quite sure right away.
VladoI only act like I know everything, Rogers.
yeah.......bring on some news Vlado!)) its almost release time
Martin
http://www.pixelbox.cz
It would be best to ask at vray@chaosgroup.com, the guys will be able to give you more accurate information.
I work for a larger corporation, so we'll get it eventually. I'm still not happy about it though. RT has never been worth the money in my opinion, and STILL doesn't work properly. 90% of my early crashes are related to RT, if I even choose to use it.
Generally, in my workflow the only use i can find is the very beginning, tweak a few lights previewed by RT (maybe 1 hour of work turned into 30 minutes by RT). Then I can't use RT anymore because the features, if supported at all, won't match the final render.
Is 30 minutes per project worth it? Not in my book.
I really hope the new version is a little better and didn't just add GPU to the lineup. I tested that also....not impressed. It's got the same problem every other GPU render has. The mouse doesn't work for Squat. The actual renders happen faster, but if you can't use the mouse as good then your productivity goes down, so makes it somewhat pointless.
Hi , i bought my vray license while travelling , in my country there is no vray reseller , the question is , how will i be able to upgrade to vray 2.0 .
can it be done online ?
Best regards
Just saw the feature list of Vray 2.0 here (vray.info).
Wondering if this particular feature is the counterpart of the Maya one which it only address the direct contribution of selected light or it is a new feature in Vray where each light's indirect contribution is separated into own RE_Light_Select?
- VRayLightSelect render element to extract the contribution of individual lights;always curious...
Originally posted by duke2 View Post...is about. Does it mean it only loads tiles it sees?
Does it do mip-mapping so it loads distant tiles at lower resolution?
