Next build update?
    Not yet I'm afraid, other things keep coming up. Will get to it.
      All good, I keep crossing fingers
      Stan
      3LP Team
        Sooo greeatt, like to test that soon!
        i ll be back
        http://www.vincent-grieu.com
          Looks fantastic! Looking forward to try that.
          AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
          2D | 3D | web | video
          jiri.matys@gmail.com
          https://gumroad.com/jirimatys
          https://www.artstation.com/jiri_matys
          https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
          https://www.instagram.com/jiri.matys_cgi/
          https://www.behance.net/Jiri_Matys
          https://cz.linkedin.com/in/jiří-matys-195a41a0
            I'm using one of the latest daily's and noticed a 'use local subdivs' checkbox. Is this the 'no more subdivs' option you mentioned Vlado? Seems to make my render go faster with it unchecked....1:32 vs 0:41! And less noise. So I guess if that is what that option does it also means my scene was very poorly optimized
            • #21
              Yes.
              Well, it's the case for many of the scenes that I've seen... It's why I added the checkbox
              • #22
                can´t find in the latest daily´s...
                www.vis-art.de
                www.facebook.com/visart3d
                • #23
                  Yes.
                  Can I sign up for testing out the new features in the nightlies? I have a few scenes here worth checking out.
                  • #24
                    We will be posting a preview build at the end of this week of the beginning of the next.
                    • #25
                      Awesome now I can't wait for the weekend for 2 reasons :P
                      Cheers,
                      Oliver
                      https://www.artstation.com/mokiki
                      • #26
                        Yes.
                        Could you clarify this please? If you added the checkbox, then why does things go faster without checking it? What was the point then of adding it?
                        Kind Regards,
                        Morne
                        • #27
                          Changing the way people use vray, I guess being more automated. The "old" way would be to use subdivs defined by each material, light,... while the new way is to use MSR. Or I'm completely wrong since I don't have access to nightlies 'n stuff.
                          A.
                          www.digitaltwins.be
                          • #28
                            Morne - I think the new default is Vray takes care of subdivs for you. If you check the checkbox vray uses your materials and lights subdivs just like it usually does. So if you check it you have full control and can tweak everything, unchecked vray does its own thing. (I might be way off though - I havent tried it myself.)
                            • #29
                              Because unfortunately we do have to take care about backward compatibility The option does the right thing for new scenes, but for already existing scenes, it emulates the previous behavior for compatibility. We will add a dialog when opening old scenes asking the user whether to switch to the new settings. On the whole, wait until you get your hands on the builds before speculating about them...
                              • #30
                                I'm at work where we don't run the nightlies so I can't check, but if I recall it's under Global DMC rollout...or Adaptive Image sampler?
