Denoiser testers wanted
  • #46
    It will come out with the rest of the SP builds; you can get a build now if you email support@chaosgroup.com
    • #47
      ok ive got the latest nightly, i see (and have added) the denoiser render element.. and now? im using RT gpu.. i hit render and i dont see the denoiser render element in the vfb... do i need to wait for the render to finish? any other steps? does the "use gpu" button work?
      • #48
        I'm still adding the support for V-Ray RT, it will be a few more days.
        • #49
          ok.. damn.. ive got a load of renders to get out in -just not enough-time. denoiser would have shaved a few hours off my 15 hour times i guess.
          • #50
            Yeah, I'll try to be quick.
            • #51
              ahh dont stress it. ill survive
              • #52
                interesting, I have send e-mail too.
                • #53
                  Originally posted by khoross View Post
                  first test with vdenoiser
                  its mostly a direct lit scene BF/LC noise threshold 0.01 AA 42 with noise in refracted and shaded areas
                  attached original rendering / mild mode/ elements mode radius=3 threshold=0.002 noiselevel=0.3
                  it's a real timesaver with a noise threshold that high it cleaned up very well,
                  increasing the noise threshold just to clean up small shaded areas would have taken double the rendering time.
                  [ATTACH=CONFIG]29338[/ATTACH][ATTACH=CONFIG]29337[/ATTACH][ATTACH=CONFIG]29339[/ATTACH]
                  Your shots look really good, for some reason I cannot get my grass to stay looking nice like yours with the denoiser, it keeps washing it all together and loosing all the detail. I didn't see your setting in the denoiser either like "threshold" or "noiselevel". I tried setting the radius low but still a no go.
                  • #54
                    The "strength" parameter is way more important than the radius.
                    • #55
                      V-Ray RT GPU should support the denoiser in the nightlies from today (May 19th).
                      • #56
                        Hi donfarese, as Vlado said " strenght parameter" i had it set to 0.3 as i recall.
                        settings mentioned in my earlier post worked well even with animation & there hardly any flickering, this was with the alpha version of the denoiser, can't wait to have my hands on the final version
                        www.kobo9.ch
                        • #57
                          as in, if i download it now it should work? might just save my butt.
                          • #58
                            Yup.
                            • #59
                              hmm there are two nightlies there, one 3.3005, but with a higher nightly number ( 26776) and the other, created later 3.3501 nightly number 26775.
                              which is the one i want?
                              • #60
                                I've testet it with Phoenix Smoke.
                                Apart fom the smoke my scene is just a big grey groundplane with mtl wrapper and a sun without physical sky, instead i put a nerly black vray color in the GI environment
                                and a white color in the Environment slot to render on a white background.
                                I think this is something that properbly isn't denoiseable.
                                Using the volumetric geometry mode "kind of" works but it takes longer than a render with vollumetric mode and Col.Thresh 0.008.
                                And if you are using the volumetric geometry mode, the denoising of the shadows on the ground inside the smoke dosn't work well.
                                I think this layes propably in the nature of the denoiser, regartless its using several Passes, it is still a 2D effect and propably will never handle volumetrics in a proper way.
                                But maby you can cut the volumetrics from beeing denoised so we can denoise the environment and the shadows the volumetrics throw.
                                I allways have to turn the col.thresh below that point where I'm happy with the noise in the volumetrics to get clean shadows out of it.
                                That could do the trick i think.
                                German guy, sorry for my English.
