vray dirt vs coronaAO
  • vray dirt vs coronaAO
    Im converting a nice corona shader to vray.
    ive noticed a potential showstopper.
    wear and dirt in shader are driven by corona AO
    i replaced with vraydirt
    however my model uses normal mapped details
    corona ao correctly adds dirt and wear in the normal mapped creases and details
    vraydirt happily entirely ignores them and looks rubbish.
    is there a workaround?
    if not, seems like something that should be fixed. as it is i might have to use corona for my project (not that this is a problem for you guys... what with owning them both.. but its a ballache.
    you would have to apply the normal map at the end of the shader tree with a vray bump material (I believe)
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      could you explain more? sounds interesting but i dont follow.
        take a look at this scene.
        Dmitry Vinnik
        ShowReel:
          hm, i dont know why, if i click on that file to download it, i get ERR_SPDY_PROTOCOL_ERROR, and "this site cant be reached" same on my phone.
            its ok, i figured it out.. not sure why it works and why it is necessary, but it seems to work.
              So does this mean the shader is "calculated" from ending to beginning? That's quite a weird order. I would expect the dirt map having to come after the bump?
              A.
              www.digitaltwins.be
                That's Chrome. Other non-chromium based browsers work.
                Lele
                emanuele.lecchi@chaos.com
                Disclaimer:
                  I'm on a nightly, but here it works straightforwardly: from the sample above, i put the normal map into the bump slot of the base shader, and reassigned it.
                  No difference in results.
                  Could you share a shader that didn't work?
                  Lele
                  Disclaimer:
