How to export Z-depth channel??
  • How to export Z-depth channel??
    Hello.
    I trying to export z depth information but can't find the way.
    In the Vray Render window I get this image:
    But if I save it I get a black image.
    Using only the max render window I can see the z channel but don't even know how to save it... it always saves the final image.
    How is this Z depth thing supposed to work!??
    Can someone give some directions!?
    Thanks
    What build are you using?
    that is the way zdepth used to work in the older builds. the newer builds (1.46.15) prduce the greyscale image looking z depth you are used to.
    Chris
    The Revitlution
      Could someone post the method for rendering zdepth with vray? I've tried it to no avail. Ended up using scanline.
      sigpic
      J. Scott Smith Visual Designs
      https://jscottsmith.com/
      http://www.linkedin.com/in/jscottsmith​
      http://www.facebook.com/jssvisualdesigns​
        Sure,
        1. Enable the z-buffer channel under the gbuffer/color mapping rollout.
        2. Set up the animation to render out to RPF, be sure to select z-buffer under optional channels in the RPF setup dialogue
        3. Render
        Easy as that. Though the antialising can be an issue, I have yet to solve that completely.
        -Z
        Chris
        The Revitlution
          Sure,
          3. Render
          -Z
          right, and if your someone without the ability to open rpf's then what do you do?
            it doesn't work to split the gbuffer channels? I've never tried it.... I always use RPF.
            Anyway, don't most compositors read RPF/RLA? You could also try OpenEXR, it looks like that has the ability to store gbuffer channels.
            Chris
            The Revitlution
              does photoshop? I guess my point is that not everyone uses vray for animation/compositing but still need gbuffer info.
                You can open an RPF in Max. Once open maybe you can save out the Z while viewing it?
                --Jon
                  this method causes combustion to crash...
                  Dmitry Vinnik
                  Silhouette Images Inc.
                  ShowReel:
                    and I agree with your point, percy
                    No, as far as I know photoshop can't. I wish it could. Out of curiosity what format dos scanline put the zbuffer in that you can open it photoshop?
                    It would be great if we render out a to a multi-layer PSD with g-buffers, ala PSD manager.
                    -Z
                    Chris
                    The Revitlution
                      works here
                      Eric Boer
                      Dev
                        what version of comb are you on?
                        Dmitry Vinnik
                        ShowReel:
                          3.02.033
                          Eric Boer
                          Dev
                            thanks...back when vray was 1.45 we used mental zdepth...also worked.
                            Dmitry Vinnik
                            ShowReel:
                            • #15
                              I'm using version 1.46.15. Why I'm I not getting the grayscale image?
                              If I use the max frame window (rendering with vray) the channel looks ok but even then I can't save this channel...it saves only the final image.
                              I only use photoshop so I can't really use RPF files.
                              Using the scanline is not an option in my particular case because I am using vrayproxies for the trees.
                              I can always do same "print screens" to get the image out but...
                              What's the matter with this stuff!??
                              With all the heavy programing and mathematics in vray how does one gets stucked in a simple "export the channel" situation like this!??
                              I can't use either scanline or RPF...Is there any other way arround this??
                              Thanks again
