Clarity on ICC colour profiles
  • #31
    One possible difference between the two modes is if you're overriding the gamma in the max file save dialog that pops up.
    That's something not possible when you copy the image to memory buffer with ctrl+c.
    Are you sure your max is set up right for LWF?
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
    • #32
      Attached you'll see the results of me loading and CCing an image in the VFB (VFB.jpg).
      Then i copy/paste it into Photoshop (the central copy in printscreen.jpg), and is shown side by side with the jpg saved from the VFB (rings.jpg), along with rings.jpg loaded in FPV and MS Photos.
      EDIT: i should hasten to add that my OS and apps are set up as default as possible, and work well under LWF. To say there was no trickery involved to get it to look right.
      Lele
      Disclaimer:
      • #33
        Originally posted by seandunderdale View Post
        Not sure if this will help, or make things worse...but these are the settings I've had to settle on to get my renders to match. Anything else makes my backplates from Photoshop change (this isnt what we want) and with these settings, I render out to png, or copy paste from framebuffer, when I open in Photoshop with Adobe98 colour space, everything matches. I have various VFB layer stuff going like a LUT, or tone mapping, but it all matches and the retouchers I hand over to don't get confused.
        Ahh thanks, seandunderdale, so you also have trouble getting the same result with VFB also.. I am also using LUT and filmic tone mapper etc. Here's a screenshot of my VFB set-up in this scene in question. I ended up turning off the tone mapping in that section but it gave me the same result as using srgb.
Name:	Vray framebuffer saving issues.jpg
        www.CoastalVisualization.com
        • #34
          you are probably displaying srgb in frame buffer and saving 2.2 with 3ds max. hence the difference.
          Marcin Piotrowski
          youtube
          CGI OCIO config 04
          • #35
            Ah ok, the frame buffer has changed quite a bit since I last used Vray, I have the display correction set to none, and srgb its set to off, Is there another place I need to check my settings?.
            • #36
              most likely scenario for you is to display 2.2 (not srgb) and save 2.2. that’s it.
              Marcin Piotrowski
              youtube
              CGI OCIO config 04
              • #37
                Ive tried that and its the same deal unfortunately.
                • #38
                  “save in image” in LUT layer checked?
                  Marcin Piotrowski
                  youtube
                  CGI OCIO config 04
