Are you also adding this feature to regular vraylights? I would like to map an avi to a vraylight, to simulate a tv screen.
That would be nice!
Another hack to make the regular vraylights look like it emit maps is to put a mapped plane (self illuminated) or a VrayLightMtl behind the vray lights and set it to skylight portal...
Wouldn't that be the same as just using only the mapped plane, with output of the bitmap to for example 5? That's what I'm doing now, but then all tha light is GI light, no raytraced area shadows.
@Vlado: Interesting rendering. Also nice to see how rendertimes differ between high-contrast and low-contrast images. That's as expected and nothing new, but it's been a long time since I've seen this so explicitely.
Thanks for that preview.
To get back to the discussion about the resolution of HDRI's: Isn't the prurpose of very large HDRI's that you can use them for both lighting and as a background that doesn't blur too much? So far most HDRI's I have seen were too small and just looked unnaturally blured when used as a background in the render (some people want to use the images as both background 'environment' and light source)
In this respect they make sense I think. For pure lighting it's probably faster to use a low-res version. If the shader would do an automatic (user adjustable) downsampling before starting the render it would be actually very convenient and a nice time saver, as it would eliminate the need to handle two separate texture files (the high-res and the low-res version) and do the downsampling manually (in HDRShop or Photoshop or whatever).
For the purposes of importance sampling, the dome light presamples the HDRI to a specified resolution... so that would eliminate the need for a separate blurred version of the map.
