UPDATED BENCHMARK (ITS FASTER I PROMISE)
  • #31
    the mobo only has 4 mem slots. That means I either had to go 4 gig or 8 gig... who the hell can afford 8 gigs of memory...not me...
    • #32
      Heres mine:
      Intel Dual 2.8 Hyperthreading enabled
      2 gig of memory
      • #33
        Originally posted by meanadam
        Syclone1 et all:
        Can you guys with dual core or similar AMD drop another gig of ram into those machines for test purposes? Do you have 4 slot MB with those?
        thanks.
        I mite be dropping more ram intot the AMD x2 but prob not till the end of the month.
        -dave
        Cheers,
        -dave
        ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
        • #34
          Missing a map "Plane01DiffuseMap.tga"
          Hi im missing a map with the benchmark scene "Plane01DiffuseMap.tga"
          Can you drop it up for download?
          Thanks
          Simon
          Simon Askham - http://www.supercreative3d.com Rendering with Threadripper 2990WX Asus Prime X399 36GB DDR4
          • #35
            you dont need it. it was a map max created by baking. I purposely left out textures in the benchmark.
            • #36
              ok sorry, thanks for clearin that up!
              • #37
                This was with one of my machins below but with 1024Mb.
                One thing I did notice, the time that it gives you in the backburner task Sumary said 5:52min????
                • #38
                  ya that probably includes loading of the scene file, and other stuff.
                  • #39
                    So.... Here we are again.... Dual xeons vs. AMD or X2.
                    Which is most cost effective? It seems AMD X2 costs 2x?
                    Win64 must make a difference?
                    I am hoping somebody is bored enough at work today to graph these resutls. I would also like to see a chart of $ per time.
                    Also - nobody has a P4 Extreme (840)?
                    www.studio2a.co
                    • #40
                      It looks like the Pentium 840 extreme edition and the AMD x2 4800 are pretty comparable in price and performance.
                      • #41
                        For Radiosity, yeah. Discreet throws in a bunch of Intel-optimizations in Max.
                        Wish they'd do it for AMD as well
                        • #42
                          According to that chart the 4200 & 4400 are the same. I was considering the 4400 but according to those numbers its not worth the extra cost. Thanks for posting that.
                          I really like the vray numbers more then the radiosity figures. Thats what I'm really interested in. Real world numbers for vray since thats what we use.
                          • #43
                            well I just bought the 4200. they both have the same clock speed, but the 4400 has 1mb of lvl 2 cache while the 4200 has 512k lvl 2 cache. So in certain situations, Im sure the 4400 will outperform the 4200.
                            • #44
                              Percy,
                              What size power supply is required and also which motherboard did you choose. I can't seem to find anyting on the power supply other than 24 pin connector being needed.
                              I'm ordering two of these tomorow for my farm.
                              • #45
                                heres everything I bought:
                                2 Thermaltake Thunderblade A1909 80mm Sleeve Green LED Light Cooling Fan - Retail
                                Item #: N82E16811999124 $11.98
                                1 ABIT AN8-ULTRA Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard - Retail
                                Item #: N82E16813127212 $129.00
                                1 eVGA 256-P2-N383-TX Geforce 6800 256MB DDR PCI Express x16 Video Card - Retail
                                Item #: N82E16814130231 $264.00
                                1 ENERMAX Whisper II EG565P-VE FMA2.0 ATX12V 535W Power Supply - Retail
                                Item #: N82E16817103512 $88.99
                                1 AMD Athlon 64 X2 4200+ Manchester 1GHz FSB Socket 939 Dual Core Processor Model ADA4200BVBOX - Retail
                                Item #: N82E16819103547 $527.00
                                2 OCZ Value Series 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model OCZ4002048V3DC-K - Retail
                                Item #: N82E16820146841 $372.02
                                1 TEAC Black 1.44MB 3.5" Internal Floppy Drive IBM PC or compatible system Floppy disk drive controller or connector Floppy disk drive interface cable 4MB RAM — minimum DOS or Windows®3.1X or Wi - OEM
                                Item #: N82E16821103113 $13.99
                                2 SAMSUNG SpinPoint P Series SP0812C 80GB 7200 RPM Serial ATA150 Hard Drive - OEM
                                Item #: N82E16822152018 $120.00
                                1 Arctic Silver 5 Thermal Compound - OEM
                                Item #: N82E16835100007 $7.99
                                1 Thermaltake Silent Boost K8 80mm Ball Cooling Fan/Heatsink - Retail
                                Item #: N82E16835106036 $29.99
                                1 Microsoft Windows XP Professional X64 Edition 1 package - OEM
                                Item #: N82E16837102034 $149.95
                                1 AMC 8" 4-Pin Power Cable Splitter Model Y Power Cable - OEM
                                Item #: N82E16812101203 $0.00
                                Item(s) shipped from TN Tracking Number:
                                1 COOLER MASTER Centurion 530 RC-530-SSN1 Black Aluminum Bezel, SECC Chassis ATX Mid Tower Computer Case - Retail
                                Item #: N82E16811119076 $68.99
                                Subtotal: $1,773.90
                                What's this? Tax: $0.00
                                Shipping: $85.14
                                Printer-friendly Version Total: $1,859.04
