2d transparency effect!
  • #16
    Originally posted by fixeighted View Post
    It sort of works
    Try it with a teapot and there are parts that do not become totally transparent.
    Also, this has no effect on shadows when fully transparent.
    It's early though, so I might be missing something obvious...
    For open volumes try enabling the Front shader's Thin Walled option and disabling VRay2SidedMtl's "Force single-sided sub-materials". Shadows will stay, however.
    • #17
      Shadows working is pretty crucial for the specific effect of course, though even with that limitation it might come in handy
      in some situations
      • #18
        Perhaps it's working. Thanks for the hint.
        Originally posted by hermit.crab View Post
        On a side note, are there any other workflows that will benefit from implementing the "ID Generator Textures" VRayMultiSubTex and/or the Transparency levels in the VRaySamplerInfoTex?
        Why did Chaos add that feature to V-Ray Maya? It must have been requested by advanced Maya users.
        Perhaps it will be a hint for developing advanced compositing workflows and special effect shaders like this one.
        OakCorp Japan - Yuji Yamauchi
        oakcorp.net
        v-ray.jp
        • #19
          Hi everyone. To remove the shadow, unclick "Affect shadows" in the settings of the fully transparent material
          Here is a file prepared with blend material instead of 2sided. And a video showing the result. However, I need to mention that it's not the fastest method to render.
          • #20
            I'm not sure why it appears to work with a teapot but it does.
            Doesn't work with arbitrary objects, so the attached is a sphere and a box.
            I tried primitives and they were all the same.
            Also anything with thickness makes it break, given the setup with thin-walled.
            The quest continues I guess
            • #21
              In the V-Ray object properties unclick "Visible in refractions".
              • #22
                That does indeed work, though it would create another problem, as most scenarios would involve overlapping objects and
                so would cut those off
