Texture Remapping
  • Texture Remapping
    Does the functionality in this thread exist in 3ds Max?
    (with V-Ray native functionality)
    https://forums.chaos.com/forum/v-ray...ternative-uses
    Currently, the V-Ray 3ds Max version node editor seems to have the least functionality.
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    VRayBitmaps don't have a native way to do this (unlike OSL: Bitmap Lookup). I suggest you log the idea in the Portal to see if there is interest in such an implementation.
      Currently, it can be replaced with BerconDistortion or OSL, so I won't request a special V-Ray native implementation, but I think it's Chaos' job to make the functionality as uniform as possible on all platforms even if there is no request.
      I think it would be better to close down the Ideas Portal since almost no one is looking at it.
      Instead of Ideas Portal, it would be far more user-friendly to hire someone in the forum to tag feature requests, which could also be implemented by AI.
      oakcorp.net
      v-ray.jp
        have you checked VRayPluginTex/VRayPluginNodeMtl?
        it should contain most non-3dsmax VRay supported features for vrscene conversions.
        Marcin Piotrowski
        youtube
        CGI OCIO config 04
          Originally posted by flat View Post
          Currently, it can be replaced with BerconDistortion or OSL, so I won't request a special V-Ray native implementation, but I think it's Chaos' job to make the functionality as uniform as possible on all platforms even if there is no request.​
          I agree, but every platform has a different team caring for its own users' needs.
          I think it would be better to close down the Ideas Portal since almost no one is looking at it.​
          We are looking at it, and some decisions are based on the votes there. It's just fairly new.
          Instead of Ideas Portal, it would be far more user-friendly to hire someone in the forum to tag feature requests, which could also be implemented by AI.​
          Is it not obvious that we are already doing this?
          EDIT: Also, what piotrus3333 said.
            Of course I will check VRayPluginTex/VRayPluginNodeMtl before posting on this forum.
            However, no functionality related to Texture Remapping properties was found. (I may have missed it though)​
            oakcorp.net
            v-ray.jp
              I may have said a little too much. I will reflect on that.
              It's still a new experiment, and we'll see how it goes for a while.
              oakcorp.net
              v-ray.jp
                I had posted about some OSL I wrote to do something similar. At least to let you distort UVs here:
                https://forums.chaos.com/forum/v-ray...andalone-cloud
                Perhaps it helps you. Good luck.
