dirty walls not inentional
  • #31
    http://static.flickr.com/121/268941194_fdfa5a539d_o.jpg
    It was the IR. I merged the file contents into a new scene. then I took the color mapping way down to 3 and 6 from 10 and 16. I turned the multiplier of the HDR from 5 to 20.
    The whole scene is lit form the HDR. There's no other light outside. There are reflector panles that have images of ountains on them. In vray prop I turnde their recieve GI down to .25 and Generate GI up to 1.5.
    Glass windows are invisible to GI
    Caustics is on for this one and I'm going to try another without.
    res3d
    • #32
      I'm sorry caustics is not on it the refractive in GI casutics that is on. I'll tryone without it to see what happens to render times
      res3d
      • #33
        Looks pretty cool now, It's always tough getting smooth lighting from an hdri, but when you get the light to play around inside like that I think it is worth it.
        Eric Boer
        Dev
        • #34
          A dicky IR map hey.. good that its fixed.
          Looking laot better now.
          With caustics you only need refractive GI caustics on (so that the light actually comes thru the window. There isnt much point turning on reflective as well, as neither will really bee seen unless you run the render thru PPT and that take ages.
          On the other hand you could use Vray:Caustics but in this image there is absolutely no need.
          • #35
            glad u nailed it! and its a gr8 improvement man!
            now u should check that bright spot just outside the door (top left corner of the door) and its just my monday-morning-numb-mind or that lamp is casting way too much light?
            Nuno de Castro
            www.ene-digital.com
            nuno@ene-digital.com
            00351 917593145
            • #36
              htat light is mot intentkional. I'm trying to find it's source.
              I did a rendering and it took 20 hours for a 2048-1536 which is toooo long. My settings were al high. is there something I can do to save time? Like the GI caustics things???
              res3d
              • #37
                the hdr lighting base isn helping u in speed terms...
                if u want fast results u woud be better off using sun+sky system i guess
                Nuno de Castro
                www.ene-digital.com
                00351 917593145
                • #38
                  i'll set up the scene wiht a sun and sky and see how it goes.
                  res3d
                  • #39
                    Originally posted by marcoos
                    If those are true, try this:
                    (3) Set a dome light in the scene
                    Hi Candelero, may i ask what benifit this has over vray's normal skylight in this situation?
                    in what circumstances does one use a dome light over skylight, is the question i think i am asking.
                    With the dome you have sampling subdivision controll, where one can crank up if necessary.
                    nikki Candelero
                    .:: FREE Your MINDs, LIVE Your IDEAS ::.
