New VrayLightMtl in SP3
  • New VrayLightMtl in SP3
    It seems like emiting only indirect illumination...
    www.gaell.com
    Which GI engine did you use?
    In any case, take a look here:
    http://www.spot3d.com/vray/help/150S...lights.htm#ex7
    As you can see, the final result is a combination of direct lighting and GI.
      I'm using Irrmap.
      www.gaell.com
        For your coments i supposed the vraylightMat works like vrayLight does.
        Can i get only direct light with vrayLightMat if i disable GI?
        www.gaell.com
          Yep, it will work if you disable GI and turn the Direct lighting option on.
            Direct light does not work when used in a Multi/Sub-Object material. Is that correct? At least it didn't for me.
              Can you disable GI for just that material using the VRayMtlWrapper on the VRayLightMtl...or will that mess up the direct lighting also?
              I would test myself, but it may be a week or two before I get SP3 installed due to workload.
              Ben Steinert
              pb2ae.com
                It will mess up the direct lighting.
                  I experienced that as well
                  any solution ?
                  NIR
                  3ds Max 2016/2021 (Vray 6.x), Windows 10 64bit , AMD 2990WX ThreadRipper 32/64 Cores, 128 gigs RAM , 2X RTX3090 48GB RAM
                    oh come on guys..isnt that nit picking???
                    if it doesnt work with multisub, then dont use it period.
                    Martin
                    http://www.pixelbox.cz
                      from the online help:
                      The direct illumination options currently only work properly if the VRayLightMtl material is the only material applied on the object. They will not work if the material is part of a complex material like a Multi/sub-object material or a VRayBlendMtl material. This restriction will probably be removed in a future release.
                      Alessandro
                        thanks for pointing that out
                          Thanks for pointing that out PixelJockey. Was about to pull out hairs..
                          placeboeffects.no | 3dhue.com
                            I'm pretty sure this is a known "bug". And by bug I think it's a design feature or something, ie. it's intentional. Something about it not being able to emit from a matID - it's either the whole object or nothing.
                            • #15
                              I bring up this thread to post a problem with vraylightMtl direct illumination option.
                              In the attached image you can see the same plane, the first with vraylightmtl direct illumination ON and the second with a vraylight with mesh option enabled appiled.
                              The first doesn't cast any shadow and direct illumination
                              The vraylightmtl isn't part of MultiSubObject.
                              Theorically there shouldn't be differences.
                              What's wrong?
                              Thanks in advance
