vraysamplerinfotex tip?
  • vraysamplerinfotex tip?
    is there any tips about how to use the new vraysamplerinfotex?
    Alessandro
    put it in the extra texture element and you can use it as a point pass
    a handy tut video made by headsmell (the office is smelling better already alex
    http://vimeo.com/11074371
      In SP5 you can also use the samplerinfotex renderelement directly without using an extratex.
      Regards,
      Thorsten
        LOL... thanks there old Patty
        Acually my little tutorial was outdated in about two weeks, as SP5 has samplerinfotext as a renderelement now.
        as for some tips, i've played around with some relighting in nuke with the pointpositionpass,
        If your using nuke you should check out the master class:
        http://www.thefoundry.co.uk/pkg_trai...E-C198B0171453
        Distric 9 uses of the P-Pass to help the compositors place cards in world space and some other really cool stuff.
        http://www.youtube.com/watch?v=upG81s75UD4
        Does anyone have any example of using the Reflection and refraction vector passes in comps? Looks interesting
        Alex
          is this 3D projection-like thing also reconstructable in Fusion? my stomach tells me i need the channel boolean node for this, but my head cant figure out the hole thing.
          especially by turning it 3D!
          any experiences out there?
          best regards
          MathTheRender
          emoticom AG
          www.emoticom.ch
            Alex
            U can use Stmap for reflections, but it's not easy to handle...haven't found any good solution yet, but it should be possible
              No idea for Fusion. In nuke we're using a bunch of in-house nodes. There should be something coming soon for the masses tho (not from my end tho and neither from the foundry...so dont beg! :P )
              Regards,
              Thorsten
