Vray environment fog - Using non atmospheric gizmos as gizmos for the fog effect
  • Vray environment fog - Using non atmospheric gizmos as gizmos for the fog effect
    I thought I managed to do this once but I cant seem to get this to work now...is this actually possible or did I just dream it ?
    Basically I have a land mass that undulates and I want some ground fog to rise and fall with the undulations of the land. I created a low poly version of the land and applied a shell mod to it to create some volume for the fog. I then turned off the rendering for this object but selected it to use as a gizmo for the vray env fog...didnt work though !
    Regards
    Steve
    My Portfolio
    Did you check the normals on the shell object? Does it work for other objects?
      I have used geometry as a gizmo and it works perfectly.
      Steve one thing to check is the "fog height" make sure the value is high enough to cover the top of the geometry gizmo
      Chris Jackson
      Shiftmedia
      www.shiftmedia.sydney
        shouldnt fog height be ignored when using a gizmo? or has that changed? or has it always been like that??
        www.peterguthrie.net
        www.peterguthrie.net/blog/
        www.pg-skies.net/
          The fog height is ignored when using gizmos.
            Vlado,
            Could the fog height be greyed out if a gizmo is used?
            Chris Jackson
            Shiftmedia
              Yes, will see what can be done about that.
                Sorry havent had time to check this problem. I'll try and get a look at this soon.
                Regards
                Steve
                My Portfolio
                  actually i have been having problems getting this to work too with vray 2, definitely used to work
                  www.pg-skies.net/
                    Works for me, but if you have a scene where it does not, please send it to me at vlado@chaosgroup.com - there might be something else there.
                      Nevermind, I found the problem; will post a patch for VRayEnvironmentFog here a bit later.
                        great!
                        I just managed to get it to 'work' (break) by turning on/off DR. Without DR it worked fine, turning DR on broke it straight away.
                        www.pg-skies.net/
                          Here is the patch: http://www.spot3d.com/vray/misc/vray...vfog_patch.rar
                          It will go into the next official update of course - this patch is only for V-Ray 2.00.02.
                            Good stuff. Thanks Vlado.
                            Regards
                            Steve
                            My Portfolio
                            • #15
                              Had time to finally test this out. All working fine now.
                              Regards
                              Steve
                              My Portfolio
